Well I just called every wrecker listed in yellow pages... No one has a ke70 in the whole of Perth![]()
Found oneke70 manual steering rack + outer control arm/pinions/knuckles/whatever u wanna call it.. For $200
Now what else do I needthere's a ke70 power steering rack end will I need this too?
Na pick a part closed down in Perth to high risk or some shit supposably
Somehow gotta find myself a ke70 xmember now.. Yay that'll be impossible
Double post
Originally Posted by CLG
that is REALLY helpful the pictures made the difference! cheers
"first project car" 1jz TA23its ALIVE! Well it starts... NEW RA28 to transfer everything into
http://www.toymods.org.au/forums/showthread.php?t=74574
1J 77 RA28 celica "in the build"
stock 200B wagon "low n slow" FOR SALE!
Doubt it. Otherwise people would be using aw11 racks instead of bothering to ship AE86 p/s racks from Japan...
I could be wrong though... Would love to be in this case.
ke70, ae86, ae71, ae86 power and ae71 power are the same. there is heaps on this in here. you might need to do a search. look at turbo28 ride thread and sheepers or mine.
cheers mat
AE86 power and KE70 manual racks are different. The AE86 p/s rack is physically bigger. Will take a photo some time to prove it.
An AE86 power rack won't bolt straight up to a KE70 cross member is the most important thing to remember.
sorry should have been more specific power racks are the same(well as close as can get), but all three racks will work with the same sort of work done to them with the correct steering arms and tie-rods. should note power racks will sit a bit lower by about 20mm. if you can get a power rack try and get the lines as well because those fittings are an od size but from memory later model st105 celica used the same oil line fittings for the odd sized outlet.
cheers mat
