Results 1 to 3 of 3
Thread: silvertop ecu with map
    Aug 2007
    Manila
    Default silvertop ecu with map
    has anyone tried this?
    given that the afm VS gives out 0-5V as with a map with PIM output of 0-5V
    then an additional IAT to ECU
    and an ignition switch activated Fuel pump with no more OCR.
    can the stock silvertop ecu's mapping handle such a setup with tuning?
    Default Re: silvertop ecu with map
    Metering and calculations are completely different between the two.
    For AFM ECU does not need to know the engine's VE curve, for MAP it does.
    Good luck with it, but I doubt you will achieve anything vaguely ok.
    Mos.
    Aug 2007
    Manila
    i thought that too. just wondering if someone did. i meant it to be done on open ITB's. just widening my thoughts.
    thanks for the input.
  1. late 97 on hilux 3rz turbo conversion walk through
    Last Post: 07-01-2011, 07:10 AM
  2. turbo kits for 3RZ-FE
    By ToDa30/4 in forum Tech and Conversions
    Last Post: 18-09-2006, 06:31 AM
  3. 3rzfe engine wiring diagram 98 model
    By BeRad in forum Tech and Conversions
    Last Post: 12-07-2006, 10:17 AM
