One is coolant temp the other is for the control of the cold start injector.
Obvisouly two different part numbers![]()
Someone will confirm/deny but I think the green one is the temp sensor. I can check when I get home tonight.
ok can anyone please tell me what's the deal with the two sensors in the back of the head/ water outlet.
Are they both coolant temp sensors? are they both the same part?
once again my engine is missing both so i don't know they have different coloured plugs so i imagine that they're two different things but i dunno.
Here's a pic of what i mean (i taxed this pic off here, sorry to who owns it):
[IMG][/IMG]
sweet as thanks man,
the only thing now is that the guy at peps only had the coolant temp one and didn't know anything about the cold start injector one? do you reckon i can get it from an auto parts store cause i don't wanna have to go to toyota
EDIT: wait i just thought, the small port ones are most likely the same thing ie:compatible yeah?
Or just don't run the cold start injector. I know plenty of people who don't. They are aimed more at sub-zero starting temps than what you find in Aus.
Also I'd say there are plenty that would be the same. A 4Y-E sensor looks the same at a glance. A trip to pick-a-part should net you more than you could ever use.
Hen
As Hen said, you won't need the cold start, mine never ran it even with the sotck ECU. Started fine even below zero.
Ahh, sweet as, thanks heaps guys.
Also, be careful to get the correct plug-type. I know there is a difference between smallport/bigport plugs. The bigport are the square type (like in the photo you posted) and the smallport are more rounded.
Current daily: AE92 SX Hatch
Previous rides: ST141 CSX, SA63, RT142 Avante, AE82 Twincam, AE82 GZE.
Coming Soon: Jza80 Supra... One day...
AE82 Owners Club - http://www.ae82.net
The square type green plugs/brown plugs can be interchanged if need be, you just need to mod the plug a little with a sharp knife to remove the notch that stops you from incorrectly mixing them up.
I had to do this because my green plug broke, so I used the brown one on the green plug.
I was talking about plug interchangeability between the square plugs with square plug sensors as they are often brittle and break or are brokenOriginally Posted by cuzzo
All sorted, thanks guys.
wahahaha, turns out i scored some sensors, i'll give you one guess what type they are......![]()
Can anyone confirm which is cold start and which is coolant sensor? thx
I am pretty sure the coolant is the green one as mine wasn't attached and the engine had trouble idling likely due to it not know the temp of the engine and then just dumping in too much fuel and not knowing what to do.
