well its good to know that its not your fault you can't read and thats why you spread rumours that aren't true.Originally Posted by EldarO
My EPC states JZX90 piston with pin assy as P/N 13101-88400
JZX100 piston with pin assy as P/N 13101-88410
care to explain why the internals that are EXACTLY the same have a different part number.
would you like me to waste my time looking up any other internal differences for you? port design, combustion chamber shapes, valve materials etc?
unless of course you have actually had hands on experience to KNOW 100% what you are about to tell ppl is correct then maybe some research on your behalf wouldn't go astray.
linden
Originally Posted by WHITCHY
And where does he quote part numbers to substantiate his claim.Originally Posted by EldarO
If in doubt power out
It's on teh intahwebs, it must be true....Originally Posted by 7MA61
guys who gives a fark ay, eldar never mentioned head of valves or shit anyways as i only asked for block differences, everyone knows the heads are diffierent.
Not worth argueing about really.
Lets keep it friendly.
Matty
PFC for VVT 1JZ (JZX100) is still being made, mine was $817 inc delivery from greenline just a couple of months ago.
I believe the HKS vcams have just stopped being made though?
If the blocks are the same then...2JZ block under a VVT 1J head, can it be done?
I've heard it can't be done with VVT 2JZ block and regular won't go though?
There is a jzx100 mark II built by Rasty for Tsukuba time attacks that has a VVTi 1.5JZ. So its definitely possible.
Don't know, theyre still on their website?Originally Posted by S_E
http://www.hks-power.co.jp/products/...lcon_data.html
Adaptronic is far from expensive and will control vvti if you so choose.
can they run a 36-2 pickup? may need some slight programing to get the right control.Originally Posted by JustCallMeOrlando
linden
The adaptronic can run the 36-2 pickup and do closed loop VVTi control, they developed the VVTI control on a beams 3S
Cool, something I want to do eventually, without the legalities and stuffing around with wiring of the older non-vvt 2J or even the vvt 2JOriginally Posted by jimmmayyy
Originally Posted by whatthe?
I heard on jzx100.com......but looking on the greenline site HERE, it looks like just the IN and EX kits are discontinued? while just the IN kits are still available, but who knows what the real story is if it's still on the HKS site??
sorry to get off-topic...
