Hey Matty
Sumps interchange
Mounts are also interchangable/
I dunno about the flywheel...
Hey guys im chasing some info on the differences between these two motors in regard to wot is interchangable etc.
Will the sumps interchange?
Will the engine mounts interchange (alloy ones on block that is)
Are the flywheels the same
Basically if i had 1 of each of these motors could i mix and match parts back and fourth on the blocks. I mean the outside of the block, not pistons, crank or rods.
Matty
Hey Matty
Sumps interchange
cheers mate, that solves most my questions
Matty
				I put JZX81 alloy mounts and a JZA70 flywheel on my JZX100 engine
Awesome!! that clears up all i needed to know.
Thanks guys
Im off to buy a jzx100 manual cut then
Matty
Are the vvti 1jz's single turbo cuts significantly more expensive than the twins?
I know that getting the vvti crankin on an aftermarket ecu is a lil tricky (expensive), it just seems like a better motor to start with unless you plan on ditchin the single straight away....
they're more expensive, AFAIK you cant one of the cams, and even if you had something custom made up, it'd be expensive as fuck.
management to run VVTi is expensive.
internals are exactly the same, and ive read somewhere they run a higher compression ratio.
just a fancy 1J with a dicky cam and a single from factory.
Autronic SM4 will run VVTi without any further mods or "options", as will a power FC (hardly "expensive as fuck" at $1100 for the PFC), a pair of HKS VVTi 1J cams can be had for $1200.
Elmo got one thing right (gasp). they run 9.1:1 comp, instead of 8.5:1 like the twin turbo version. They also have a beams head (and no, you cant bolt a standard 1J exhaust mani on, port and stud positions are different)
i dont count the PFC as they arent made anymore, but i guess you'd be able to find one second hand but new in box.
link to hks VVTi cams? i couldnt find a fucken thing when i was looking for em a few months back, thought it had to be custom.
PFC is still available new in box on ebay. There will be new stock floating around for years. Most new decent aftermarket ECUs have cam control anyway. If you want to cheap out on a microtech, well, hey.
I've got the contact for cams in my email inbox, didnt find him on google. Actually found him on altezza club forums, although I belive he's active on nissan silvia as well. If youre really interested I'll PM you his details
Neg rep huh Eldar? Don't care if you think I'm being a dick. I'm not the only one who wishes you'd actually stop spouting bullshit as fact in the tech section
Maybe, but then few people change cams in turbo engines.Originally Posted by EldarO
That's misleading - there are entry level and midrange products available; products capable of running VVTi are generally no more expensive than any other midrange product. If you wish to use an entry level product, you're limiting yourself in many more ways that just the inability to run VVTi.Originally Posted by EldarO
That's a contradiction.Originally Posted by EldarO
There are several differences with most VVTi engines that make them better engines than the non-VVTi versions.Originally Posted by EldarO
As an objective toyota enthusiast you should be able to recognise that, and not just bad mouth better technology because of a possible subjective experience.
And neg repping someone for correcting your misinformation? Please!!
Mos.
There is a new power FC for the 1JZ VVTI soarer on eBay Right now and they have been commonly available over the past year on eBay at least.
Originally Posted by lojik
Yeah mate they seem to still be more expensive than the twin turbo ones, plus they are generally a few years newer also, hence lower k's in most scenario's.
An awesome engine in stock form if you ask me.
I wont be looking to upgrade management or even mod it so as far as cost go's im not concerned there, the cut already has front mount and hks pod, thats enough for what i want.
Matty
hmmmm, did that answer all your issues?Originally Posted by Mos
once again, you all jump to conclusions, thinking im being a know-it-all when in fact im expressing my views.
everything you've bitched about has been cleared up quite easily, and you'd rather jump to a conclusion than ask for an explanation, and you'll no doubt do the same here.
anyway, ill leave mattys thread alone, feel free to respond, as i know you will, but safe to say, i dont give a fuck anymore.
Toyota would not change compression via HG thickness and you aren't going to gain 0.5:1 comp just from doing it unless the standard gasket was pretty farking thick.
If in doubt power out
