Results 1 to 11 of 11
Thread: mz20 standard brake size?
    Junior Member Grease Monkey Intense's Avatar
    Default mz20 standard brake size?
    Anyone happen to know the standard dimensions of the mz20 brake rotors and if any other models use the same rotor?
    Sa22c Series 1 rx7, 12a extend port, 900rwkw @ 93,320 rpm sold
    Ra65 celica hatch, 22re with 2.25" exhaust, 500Nm @ 27rpm sold
    Ae86, 4agze, 170Takumi Powers @ 11,000 rpm
    Apr 2007
    Default Re: mz20 standard brake size?
    MA70 and JZA70. 300x22mm.
    Junior Member Domestic Engineer 1200det's Avatar
    The soarers are around the 280mm region and not the 300mm like the Supras
    Current Toys
    97 Pajero EVOLUTION
    04 Lexus ES300
    92 Hilux 2wd
    Junior Member Backyard Mechanic AeRoKaBn's Avatar
    ga70/jza70/ma70- 300mm
    gz20/mz20- 280mm
    seems a bit silly that toyota put smaller brakes in a heavier car but ahh well i stand corrected
    Apr 2007
    1200det, the small capacity sixes have the 280mm discs. All of the large capacity ones have 300mm. My car has 300mm discs and it's bog standard.
    Forum Sponsor Automotive Encyclopaedia dori dori's Avatar
    Std MZ20 is 280mm.
    Apr 2007
    hahah i'm gonna have to look this up. Mine and every other MZ i've seen had 300mm discs.
    Do MZ's then have different calipers to MA's?
    MZ and MA do have the same calipers although the mounting plate and disc are the only difference , All GZ and MZ Soarer have as factory fitted 280mm
    Current Toys
    97 Pajero EVOLUTION
    04 Lexus ES300
    92 Hilux 2wd
    I have a pair of slotted 280mm rotors for sale if anyone cares.
    reason I ask is because tsuchiya's trd ae86 has an mz20 brake upgrade. Looks to be a good cheap way to get better braking performance for ae86's
    Beer Fueled Domestic Engineer doobs's Avatar
    Quote Originally Posted by dori dori
    Std MZ20 is 280mm.
    this is correct, mine were
    By The Witzl in forum FAQ
  2. Brake Gurus required
    By infotechplus in forum Tech and Conversions
    Last Post: 07-04-2007, 03:18 PM
  3. Need help diagnosing a brake problem – mz11
    By Johnzoku in forum Tech and Conversions
    Last Post: 05-04-2007, 07:56 PM
  4. Replies: 3
    Last Post: 06-07-2006, 06:11 PM
