Results 16 to 27 of 27
Thread: 1jz single turbo VVTI block differences to 1jz twin turbo
    Forum Sponsor Conversion King
    Default Re: 1jz single turbo VVTI block differences to 1jz twin turbo
    no it isnt, the internals are exactly the same, as proved by the EPC, however, you can actually vary compression ratios, via head gasket thickness, and a range of other ways, which they've quite obviously done here, as the internals ARE exactly the same.
    well its good to know that its not your fault you can't read and thats why you spread rumours that aren't true.
    My EPC states JZX90 piston with pin assy as P/N 13101-88400
    JZX100 piston with pin assy as P/N 13101-88410
    care to explain why the internals that are EXACTLY the same have a different part number.
    would you like me to waste my time looking up any other internal differences for you? port design, combustion chamber shapes, valve materials etc?
    unless of course you have actually had hands on experience to KNOW 100% what you are about to tell ppl is correct then maybe some research on your behalf wouldn't go astray.
    linden
    Western Aus
    And where does he quote part numbers to substantiate his claim.
    If in doubt power out
    Quote Originally Posted by 7MA61
    It's on teh intahwebs, it must be true....
    W.A.
    guys who gives a fark ay, eldar never mentioned head of valves or shit anyways as i only asked for block differences, everyone knows the heads are diffierent.
    Not worth argueing about really.
    Lets keep it friendly.
    Matty
    Apr 2007
    PFC for VVT 1JZ (JZX100) is still being made, mine was $817 inc delivery from greenline just a couple of months ago.
    I believe the HKS vcams have just stopped being made though?
    If the blocks are the same then...2JZ block under a VVT 1J head, can it be done?
    I've heard it can't be done with VVT 2JZ block and regular won't go though?
    Balloon Slayer Backyard Mechanic jimmmayyy's Avatar
    Apr 2007
    There is a jzx100 mark II built by Rasty for Tsukuba time attacks that has a VVTi 1.5JZ. So its definitely possible.
    Quote Originally Posted by S_E
    Don't know, theyre still on their website?
    http://www.hks-power.co.jp/products/...lcon_data.html
    Adaptronic is far from expensive and will control vvti if you so choose.
    Quote Originally Posted by JustCallMeOrlando
    can they run a 36-2 pickup? may need some slight programing to get the right control.
    linden
    The adaptronic can run the 36-2 pickup and do closed loop VVTi control, they developed the VVTI control on a beams 3S
    Apr 2007
    Quote Originally Posted by jimmmayyy
    Cool, something I want to do eventually, without the legalities and stuffing around with wiring of the older non-vvt 2J or even the vvt 2J
    I heard on jzx100.com......but looking on the greenline site HERE, it looks like just the IN and EX kits are discontinued? while just the IN kits are still available, but who knows what the real story is if it's still on the HKS site??
    sorry to get off-topic...
  1. 1ggte single turbo conversions
    Last Post: 08-08-2011, 05:21 PM
  2. **HELP** Twin turbo to single 1jz setup.
    By DLA11D in forum Tech and Conversions
    Last Post: 11-07-2011, 11:06 AM
  3. 1GGTE single turbo CT26 conversion ?
    Last Post: 27-03-2008, 09:51 AM
  4. Single or Twin Turbo
    By Ashe in forum Tech and Conversions
    Last Post: 09-08-2006, 09:23 PM
  5. 1G Single turbo donor playoff
    Last Post: 23-07-2006, 04:26 PM
