Results 31 to 45 of 66
Thread: The 1UZ Mods Thread
    Default Re: The 1UZ Mods Thread
    If its a V8 box, its an A341E.
    I'm yet to see an A340E on the back of a 1UZ.
    A341E will have a 30-41LE plate on it, A340E will have a 30-40LE plate on it.
    tasmania
    oh, ok. i just saw somewhere that only the crowns had a341e's or something like that.
    i got the box separate from the motor, but it' supposed to be a v8 one, it's bolted on anyhow.
    so, what does the shift kitting involve, other than me pulling the farkin motor out again to get the farkin box off!(i'm not crawlin under there to lift the bastard out- been there, not doin it again!)
    is it woth getting a higher stall torque convertor? just so the commodore loser's quiver in there pants when i flog them from the lights
    beer me!
    tasmania
    i'm gonna probly make my own headers if i can't get the standards to fit. just to make sure, the runner pairs should be: 1 7, 3 5, 2 8, 4 6?
    beer me!
    Montrose
    Shift kitting... you mean valve body changes, or connecting up a so-called 'manual controller?'
    Neither requires removal of the box. Manual controller is wiring only, while changing the valve body requires removing the pan. It is at this moment that you will appreciate Toyota auto's actually having the obvious inclusion of a drain plug, *unlike certain inferior transmissions.*
    tasmania
    yay, i might be able to do some of that with 1.25 arms/hands!
    beer me!
    tasmania
    i just spotted a "perfect power smart tuner SMT6" on ebay. does anyone know whether this is capable of running an auto 1UZ?
    i'm guessing no, cuz it's $30 atm, but if anyone knows otherwise or has experience with one of these tell me please.
    beer me!
    Its a piggy back.
  8. #38
    tasmania
    Its a piggy back.
    dahh, i knew that, i wanted to know if it would work without disrupting the auto.
    beer me!
  9. #39
    Yes, it ill work without disrupting the auto.
  10. #40
    The way I read it, you asked if it was capable of running the auto.
    If you are asking if the SMT6 is compatible with the stock ecu, then yes, it is.
    There are a couple of guys on soarercentral who have installed them.
    No real results yet though.
    Retail was around $750ish I think?
  11. #41
    tasmania
    thanks, yeah i wanted to know if it would run the engine/auto, essentially stock, with no hassles.
    i've got nothing to lose for <$50!
    edit: i'm going crosseyed, the postage is $30! the piggyback's $500. ...prepares for slapping....
    beer me!
  12. #42
    Soarin' Capoeirista Backyard Mechanic Malicia's Avatar
    @ Joe
    Has anyone tried the BFI mod?
    Alot of the PlanetSoarer & SoarerCentral guys have doen it, and I'm thinking of givign it a try.
    http://www.planetsoarer.com/BFI3/bfi3.htm
    This is ofcourse directed at those with V8 Soarers..........
  13. #43
    Its the first step. Increase the air in, then the air out.
    So do the BFI.
    CoronaC, The Supercharger as mentioned earlier is at http://rushimports.com.au/index.php?...ba4cf60a31b318
    not www.rustimports.com.au hehehe
  14. #44
    Junior Member Grease Monkey CoronaC's Avatar
    Quote Originally Posted by acmtt
    Yeah maybe thats why it didnt work , i found the link to it since i posted that though.
    Has anyone tried those Jaycar 'Digital Fuel Adjuster's and Hand Controllers on a 1UZ before? If you have what are they like, any good results from them? (both power or eco wise)
    Worth it in the end, or save the money and spend it on something else?
    Im thinking about having a go but im not to crash hot on making those electro gizmo kits (asuming they arnt prebuilt, which im guessing there not)
    Does it come with at least basic instructions on how to wire up to your car?
    Is it fairly easy to use the hand controller to tune or is it a bastard of a job?
    Only costs around $160 for the Fuel adjuster, hand controller and connection cable + what ever else it will cost for install, so say $180-200 total, I think its worth a try if other people have gotten good results from them. Just want to find out a bit about them first.
    Chris
  15. #45
    tasmania
    Quote Originally Posted by CoronaC
    Chris
    i was gonna get one of these until cruzida pointed out that they won't work on the common nonvvti 1uz, because the adjuster won't work with the early 1uz's type of AFM
    also, that $160 is a kit, you have to put the ciruit board and everything in
    beer me!
  1. 1uzfe mods
    By CoronaC in forum Tech and Conversions
    Last Post: 16-02-2006, 01:05 PM
  2. How to edit a thread title?
    Last Post: 11-01-2006, 09:53 AM
