Thanks for that info cruz, yeah that was the site i saw on lextreme or clubsoarer, they seam to have been offline doing updates for a week or two now (since i first found out about the site anyway)
When you say...
Do you basically mean that after getting the cams get a stand alone ecu and not a piggyback unit?My rule of thumb, if you change the cams, piss the AFM off.
Would you still be able to run and properly tune a piggyback unit with cams or is it just better to go stand alone unit to control engine and stock ecu to control g/box?
What would be a good stand alone ecu to go for if i was to look into getting one to control the engine while stock ecu controlled the g/box and what type of price range would it be in for purchase/install/tune?
I have no idea when it comes to ecu/electrics (if didn't notice)
As for the exhaust, I've been looking on lextreme for other peoples setups that give better power output, but without being too loud (I hate loud exhausts) and if the celsior headers can support up to 200rwkw then i would leave them be for time being.
How would this setup be...
Stock Extractors -> 2xHigh flow cats -> X or Y pipe ? -> 2xResinators (maybe?) -> 2xRear mufflers
Dont know if this would be a good setup or not
Have you got cams for your engine yet cruz? if you did go with the kelford cams which one would you look at getting? custom made ones to suit your engine better or just their mild cams they have on their site?
Chris
), then any decent ECU should be able to use the output from any AFM (assuming it is just a 0-5V output) in place of a MAP. so then you just pick your AFM by size so it doesn't max out and doesn't restrict as much and away you go...
