Mate left his half on after launch, seemed to work ok but I'm not an expert.
Callum
would you be able to automate them between each gear change?
i thought OP was talking about antilag, not launch control?
Callum
you have two option on the throttle opening side of things
1 use an xf idle control valve, these flow a fair whack of air and can be controlled by the ecu for antilag aswell as decent idle control
2 use a commodore boot release solenoid on a second throttle wheel to actually hold the throttle open by the amount you require, easily adjusted to suit the length required but are only on/off and you can't hold the soleniod open for too long or it may get hot
(10secs max)
linden
Originally Posted by WHITCHY
