Results 1 to 15 of 18
Thread: setting up antilag : HELP
    Default setting up antilag : HELP
    i would like to have a little play with my antilag setting on my ecu, for those that have had experience with tuning and setting this function up - can u please give me some tips as to hopw much % fuel i should increase and how much % timing i should pull out
    User Conversion King
    NWA
    Default Re: setting up antilag : HELP
    what ecu is it.
    a few people have set it up on the adaptronics. youll also need an air bypass
    have a search on their forums
    hello
    ems 8860
    setting i have to play with are
    turn on above rpm
    turn on above tps
    turn off above kpa
    ignition missfire seq.
    fuel trim %
    ignition trim%
    It depends on what ECU you have...
    Which are you running
    Basically, try to get timing to be AFTER TDC,
    And add in around 8% of fuel.
    My Dead Supra...
    Quote Originally Posted by ReQuieM in the A70 Thread
    There is some serious talent in this thread for linking anything to fuckin gay sex. Its extraordinary.
    RPM set to your launching RPM
    TPS set to 40%
    KPA just above your max boost you wanna run
    fuel 8% +
    ign -100%
    My Dead Supra...
    I don't know how you set the sequence.
    I just use my launch control to cut ignition, with a hot exhaust and raw fuel, I see 4PSi at a 3000RPM limit
    My Dead Supra...
    search google for "antilag retard"
    search google for "antilag", retard
    That's not very nice
    Forum Sponsor Conversion King
    but there is a f*#kload of info on the first page if you look it up
    it was meant to be a funny ... however it was also the best search i could come up with quickly to weed out most of the crap...
    eng tips has some discussion also
    http://www.google.com.au/search?hl=e...anti-lag&meta=
    are you going to keep throttle open somehow?
    I think my subtle misquote was missed.....
    that was just a variation on the theme
    didnt miss it just though id google it to see if O?C had stuble across something funny (but alas i was dissapointed)
    linden
    you can keep the throttle open by opening up the aux-air-valve somehow - does the same as cracking the throttle.
    New Zealand
    Old idle up cables from diesels work quite well, mate used this on his WRX rally car.
    Callum
  1. alternator pulley idler torque setting
    By SpleenieMcSpleen in forum Tech and Conversions
    Last Post: 25-03-2006, 12:19 PM
  2. Torque setting for the hub nut 86 AW11 MR2
    By Chubs in forum Tech and Conversions
    Last Post: 07-03-2006, 04:30 PM
  3. setting up a fuel system
    By Cam-Rush in forum Tech and Conversions
    Last Post: 17-02-2006, 10:39 AM
  4. antilag systems - WRC mitsu style
    Last Post: 03-02-2006, 12:04 PM
