Results 16 to 18 of 18
Thread: setting up antilag : HELP
    Default Re: setting up antilag : HELP
    would you be able to automate them between each gear change?
    i thought OP was talking about antilag, not launch control?
    New Zealand
    Mate left his half on after launch, seemed to work ok but I'm not an expert.
    Callum
    Forum Sponsor Conversion King
    you have two option on the throttle opening side of things
    1 use an xf idle control valve, these flow a fair whack of air and can be controlled by the ecu for antilag aswell as decent idle control
    2 use a commodore boot release solenoid on a second throttle wheel to actually hold the throttle open by the amount you require, easily adjusted to suit the length required but are only on/off and you can't hold the soleniod open for too long or it may get hot
    (10secs max)
    linden
  1. alternator pulley idler torque setting
    By SpleenieMcSpleen in forum Tech and Conversions
    Last Post: 25-03-2006, 11:19 AM
  2. Torque setting for the hub nut 86 AW11 MR2
    By Chubs in forum Tech and Conversions
    Last Post: 07-03-2006, 03:30 PM
  3. setting up a fuel system
    By Cam-Rush in forum Tech and Conversions
    Last Post: 17-02-2006, 09:39 AM
  4. antilag systems - WRC mitsu style
    Last Post: 03-02-2006, 11:04 AM
