Results 1 to 13 of 13
Thread: 2JZ-GTE compression values - Results
    Default 2JZ-GTE compression values - Results
    Hiya,
    getting a compression test done on a '96 Supra 2JZ-GTE, what sort of values should I be looking for in a healthy engine? It's done around 52,000ks.
    The figures I got back for compression test were:
    1 2 3 4 5 6
    170 155 175 160 160 175
    Is the roughly 10% variance between the highest and lowest anything to be concerned about? I noted the acceptable variance mentioned on the link posted above was 14psi but that anything over 156 was ok...
    Cheers, Chris
    Cheers, Chris
    Default Re: 2JZ-GTE compression values
    unless you've seen the interior of the car it came out of, I'd doubt the 52,000 claim.
    even my 2000 2j has a few more than that on it.
    Apr 2007
    I did a comp test on my 2jzgte, and from memory it was around 190 psi, higher than i expected, i was using good quality gauge ..suspect the engine had around 100 plus k's ..
    190psi is very high for a turbo engine.
    (maybe this comp test was done on a warm engine, with very thick oil, WOT)
    Go drifting...
    Apr 2007
    I agree, thats why it suprised me a bit, Comp test should always be done warm to get an accurate figure, & of course at WOT, oil was only standard weight, i would be suprised at cranking speed if heavy engine oil would make much of a difference ... ( I am obviously talking dry test only .. )
    Xistant
    Guest
    AFAIK to complete a compression test, engine should be run in prior, to get the best reading with WOT .
    Junior Member Backyard Mechanic manny's Avatar
    Non VVTi 2JZ-GTE procedure and specs here
    http://mkiv.com/manual/manualtt/comp...eck/index.html
    Anyone got specs for the VVTi 2JZ-GTE?
    GSE20 IS250 - daily
    Default Re: 2JZ-GTE compression values - results
    Yeah I'm always careful when checking out a car that is supposed to have such low km on it - I've seen a couple that were clearly clocked.
    This one's interior and paint-job were immaculate, suspension bushes looked really good and no noticeable wear around the shifter or seats, there weren't even any insects in the intercooler. It looks like a brand new car.
    1 2 3 4 5 6
    Cheers, Chris
    Default Re: 2JZ-GTE compression values - Results
    any opinions?
    Cheers, Chris
    did you do a wet & dry test? that would provide you with more information.
    pull a plug and look at colour?
    #2 seems a tad low but a wet & dry test would confirm if there's issues with rings
    Apr 2007
    Usually 10 % is a Maximum recomended difference across the cylinders that you want to see, yours is a bit over that, sometmes even rechecking a low cylinder is worth it to confirm, as has been mentioned you then need to do a wet test to help confirm if its rings or valves ...
    vic
    And if a bit of shit fell down the plug hole after pulling the plug out that stuffs the reading, very common on plugs that are dead verticle. If you have a close look first you will see fine sandy stuff around the plug compartments.
    Dave
  1. 2jz Bottom End 1jz Head
    By P.I.M.P.I.N. Soarer in forum Engine & Driveline Conversions
    Last Post: 17-04-2013, 06:27 PM
  2. My high compression + boost concept
    Last Post: 18-06-2012, 10:40 PM
  3. 1jz to 2jz
    Last Post: 30-11-2006, 07:52 AM
  4. 1jz vs 2jz heads
    Last Post: 04-05-2006, 10:07 AM
  5. 20v compression (compression test)
    By 2revup in forum Tech and Conversions
    Last Post: 20-03-2006, 06:06 PM
