Results 16 to 30 of 33
Thread: Are the RWD waterpump components for 4AGE still available?
    Hoppers Crossing
    Default Re: Are the RWD waterpump components for 4AGE still available?
    the w1062 is the same i got for my 4AFC p00 motor.
    and yeah i'm with sam, the bearings won't last as its not designed to have the normal fan hanging off it......maybe its dual purpose is the waterpump>?
    I think a thermofan is the way to go so you can hit two brids with one stone, but thats just my personal opinion
    Junior Member Grease Monkey Beserker99's Avatar
    Quote Originally Posted by Grega
    Hmmm, that's quote interesting..but yeah, the powermax book listed the W1062 as the RWD waterpump for the 4age. So I'm sure the bearing is strong enuf to use the factory clutch fan.
    Raastler Grease Monkey
    Quote Originally Posted by Beserker99
    It's been mounted on Beserker's engine for more than 2 years and hasn't shaddered with many reving dances. I know people of put fwd pump on and used the clutch fan to break it months later. It is also the RWD one because the pulley lines up properly and the kneck is longer on the poomp
    Traditionalist Domestic Engineer parrot's Avatar
    I've got a NPW (Nissan Pump Mfg Co Ltd) new in box sitting here, again only the front half, for rear wheel drive 4AGE's.
    The listing on the side says it is for AE86's, AA63 Carina's and AT141 Corona's.
    Part numbers also listed next to a large T-55 (the NPW number?) are
    16110-16010 (this is for an AE86) &
    16100-19095
    New Zealand
    16110-16010 is the old p/n for the half
    16100-19095 is th ep/n for the full pump
    toyota sells all 4 cyl water pumps for $120 here
    please, no more PMs!
    just jogging my memory, its been a while since i put my 4a in. a rwd water pump will get rid of the remote thermostat housing, but doesn't it get in the way of the alternator or something then? id love to get rid of the remote housing, i hate the freekin thing.
    Hoppers Crossing
    yes
    if you use the std 100kw FWD alternator mounting the alternator is in the way
    the other issue is the top coolant outlet needs to be specific also for the RWD setup ; the FWD one does not have the piece that goes between the top outlet and the back of the pump
    you could mount the alternator on the passenger side, but, that will require custom brackets (i think there was a low mount GZE alternator bracket)
    maybe a 4AC alternator bracket would work on the passenger side?
    i know my 4AFC mounts the alternator up too high (it would foul on the dizzy)
    clubmans use a holden v8/holden 6 bracket modifed for the lower and a custom top bracket (and smaller daihatsu alternator) however we're digressing here from water pumps
    queensland
    the alternator bracket has just gone obsolete with Toyota. my last orders just got squashed in japan. I have the proper rear drive pumps and water outlets at work. www.roadandtrack.net.au
    the factory bracket mounts the alt on the exhaust side right? right where my turbo lives.
    Factory RWD mounts the alternator low under the intake manifold.
    GZE mounts all accessories on the exhaust side.
    Hoppers Crossing
    sounds like an alternative is required.
    just trying to shy away from the remote thermostat idea from the FWD 4A setup, but, if i have to, i have to...
    New Zealand
    Quote Originally Posted by terryo
    not true..... just checked... still avail in japan
    heaps in stock here and there.
    Hoppers Crossing
    mr revhead............i emailed you a while back but no response....?
    terryo......i'm still to call you, stuck on a course this week mate.
    New Zealand
    sometimes some emails get missed.... or i forget to reply!
  1. Replacement waterpump for bigport rwd 4age
    By ViPeR_NiPPleX in forum Tech and Conversions
    Last Post: 18-09-2007, 07:46 AM
  2. 1GGTE Engine Specialist in Adl (Waterpump)
    By Axerus in forum Tech and Conversions
    Last Post: 26-08-2006, 08:05 PM
  3. 4agze waterpump Help
    Last Post: 18-05-2006, 07:05 AM
