Page 12 of 12 FirstFirst ... 2101112
Results 166 to 170 of 170
Thread: Wideband O2 sensors, a few questions.
  1. #166
    Default Re: Wideband O2 sensors, a few questions.
    That's no excuse though for the lack of customer support people are complaining about.
    very true. I hope I don't need it!
    Current rides...
    2) White RA25ST
    1) Red RA28LT (NOW WITH 1G )
  2. #167
    Melbourne Victoria
    whiztl and any body else that uses a LSU.4.2 they have a very short life span as i used 2 in 12 months on my race car just for lambda settings ,i have since gone over to a NTK wide band sensor and so far have lasted 18 months and is going all of the time ,but my set up uses a preheat so it take about 3 min to heat up but thats ok as it takes about 5 min to warm the motor up any way
  3. #168
    I've actually never had a sensor fail in 3-4 years, and I've always run Bosch except for one NTK. I've collected half a dozen spare LSU's because I was told to expect them to fail... but that's yet to happen.
    LSU's were actually used on the VE Alloytec V6 (before they changed to narrowband for cost reasons) and given the k's they do without failure, general durability isn't an issue. I beleive that early failures are application related - whether that be thermal or physical shock, overheating, condensation (mounting at 10-2pm isn't a sure way to avoid this), or leaded/race fuels.
    NTK sensors have a larger chamber volume which is more resiliant to heat, but also makes them a bit slower. Perhaps your issue could be heat related Glen?
    Current rides...
    2) White RA25ST
  4. #169
    Melbourne Victoria
    the NTK was double the price of the lsu.4.2 and im not using leaded at all. also this NTK is much faster reading than the lsu and the sensor is in the same posi and we also have 1 in the exhaust at the back to double check every time its been tuned on the dyno
    ps i vote for I 2 software its fantastic much better than the old data log motec interpeter 2,9 software
  5. #170
    That's weird! By design, I can't see any way that the NTK design can be faster. Can you recall which sensor it was? I'll have to check it out, maybe they've changed design.
    Current rides...
    2) White RA25ST
  1. 2JZ questions
    By kingd in forum Tech and Conversions
    Last Post: 20-03-2007, 11:31 PM
  2. sensors in exhausts
    By Adsport in forum Tech and Conversions
    Last Post: 06-03-2007, 10:09 PM
  3. Aftermarket Engine Management - Burning Questions
    Last Post: 01-07-2006, 06:30 AM
  4. Theory: Heat sensors in cylenders
    By Nim in forum Tech and Conversions
    Last Post: 30-06-2006, 05:18 PM
