Page 83 of 85 FirstFirst ... 33738182838485 LastLast
Results 1,231 to 1,245 of 1266
Thread: 3T GTE Tech
  1. #1231
    Sep 2009
    Default Re: 3T GTE Tech
    Has anyone found a source for or had an MLS head gasket made up? I read somewhere of a shop in NZ that has produced some before??
  2. #1232
    nuts Grease Monkey
    auckland
    Quote Originally Posted by brownhornet View Post
    yes there's a shop (now) in Kaitaia NZ (formerly Kumeu) that makes customised mls gaskets and has the TG pattern. i started a group buy thread some time back. my friend races a 450hp 3tgte with them. theyre about 1.6mm thick with combustion chamber crush rings and the middle layer looks to be a graphite substance but unsure. They're race proven anyhow and need flat surfaces to seal correctly. If you can't find a contact for them let me know or if cant be bothered looking I have a spare one.
    Sent from my GT-I9300 using Tapatalk
    -Mark
    E2 + E7 fan
  3. #1233
    nuts Grease Monkey
    auckland
    try this
    https://yellow.co.nz/y/gaskets-unlim...src=name&c=895
    -Mark
    E2 + E7 fan
  4. #1234
    Sep 2009
    Cool. How is 1.6mm vs standard thickness? What bore size is your gasket? I've got a standard block so looking to do the head stud mod and upgrade the HG before winding a bit of boost in but don't want to lower the compression ratio too much from stock
  5. #1235
    nuts Grease Monkey
    auckland
    sorry about phone pics but that gives an idea..
    -Mark
    E2 + E7 fan
  6. #1236
    Kameari do MLS head gaskets for TG engines.
    Sent from wherever I was at the time using Tapatalk for Android.
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
  7. #1237
    Sep 2009
    Only in 90mm though...
  8. #1238
    Sep 2014
    Hi all just thought id some specs of mine in.
    3tgte fully rebuilt by a previous owner ( fingers crossed on the build quality for now )
    4x 4 agze twin coils
    custom flywheel and sensor setup at the front for the CAS
    evo 550 injectors
    big external fuel pump and surge tank
    oil cooler
    front mount intercooler
    big ford throttle body (not sure what off)
    link storm computer
    haltech ignition
    3 inch exhaust
    custom manifold, 3 inch pipe on standard runners
    w55 gearbox
    turbo GTX 2867 gen 2, .86 rear, 18psi actuator
    210 kw atw on 24 psi, 219kw on 28 psi
    full boost by around 4000rpm but its making over 200 by 4500 then the power pretty much flat lines. looks like the standard intake runners and head just cant flow much more power.
    Anyone on here have a spare head that's been worked or stock? any fabricators on here that can make a manifold with big runners?
    thanks
  9. #1239
    Sep 2014
    3tgte dyno. Cant figure out how to upload.
  10. #1240
    Feb 2007
    Timaru
    Quote Originally Posted by Dougieta22 View Post
    Would be keen to some pictures of how that is done,
    we are building a Celica race car with a 3TGTE engine and may be keen to make something similar,
    as you get a better signal from the crankshaft direct.
    - KE70 Corolla Dx -
    - 500hp+ 7AGTE 20V turbo -
    - MRS/Hayabusa turbo **sold**
  11. #1241
    nuts Grease Monkey
    auckland
    Hey dx20vt you may be interested in eric budds race engine? 2 time gtrnz nzgt winner I believe in his white te71 levin. Running crank trigger and sync on the dizzy already. Link g4 etc. He said he was moving up to gt2 or something so needed moar power and selling his 3tgte.
    -Mark
    E2 + E7 fan
  12. #1242
    nuts Grease Monkey
    auckland
    331rwhp (at time of print) 3tgte te71 race car
    http://www.themotorhood.com/themotor...lla-that-could
    -Mark
    E2 + E7 fan
  13. #1243
    Feb 2007
    Timaru
    I know that car and have actually raced against it myself a few years back. We were pitted alongside him and had a few chats.
    Last time I saw that car it was red and was a bit... um.. agricultural.
    We are building something a bit different,
    we already have a stroker crank, rods, pistons, valves, springs, etc etc on the way from japan/usa for our build.
    - KE70 Corolla Dx -
  14. #1244
    nuts Grease Monkey
    auckland
    Noice. Do you have a build thread?? are you using the 4Y crank? This be interesting
    Haha yeah agricultural would be correct. built in a farm shed. It's come a long way since then.
    -Mark
    E2 + E7 fan
  15. #1245
    Feb 2007
    Timaru
    no not a 4y crank.
    It is a proper forged stroker crank from the states.
    No build thread yet, but have thought about one.
    Will probably wait until the car is more complete before I see if I can post a build thread.
    - KE70 Corolla Dx -
  1. 3T Versus 3T GTE conrods
    Last Post: 01-06-2007, 12:59 PM
  4. html in the tech section
    Last Post: 28-12-2005, 10:49 PM
