Page 59 of 85 FirstFirst ... 949575859606169 ... LastLast
Results 871 to 885 of 1266
Thread: 3T GTE Tech
  1. #871
    Jan 2012
    Finland
    Default Re: 3T GTE Tech
    The 3T(-GTE) have 8 counterweights so it's very well balanced internally.Factory have wanted it to be very shmoot running so they added rubber bands on the pulley.The toothed belt drive will absorb any vibarations from crank.
    Early T/R/... engines just have a pulley;no rubber in there and they run quite well as anyone can see...
  2. #872
    Quote Originally Posted by MorGo View Post
    Thats awesome news! Does anyone disagree?
    If not I will be sending the pulleys over to the engineering place that already makes them for 4A's after I get back from OS. Will look into doing a group buy if anyone is interested.
    Nath
    -Just Alloy Radiators-
    www.alloyradiators.com.au
  3. #873
    Nath,
    Harmonic balancers were added to engines for a reason by the manufacturer so should not be disguarded lightly. BUT, I ditched mine on the unicorn
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
  4. #874
    Well Rod if you did it to that bloody fine engine then I am sure I can do it to mine too!
  5. #875
    Dec 2011
    ATL GA USA
    The T engines with counterbalanced Crankshafts are very stable engine and Harmonics are not that bad or represent a big problem at all In my race T engines i use the small light aluminum front balancer from BRD and no belt at all, and never ever had a problem with harmonics and i have been as high as 580+WHP on a 3T drag motor, stock crank and 87mm pistons at 60+ PSI of BOOST
  6. #876
    Awesome news! Absolutely amped now.... I know some may think its wanky but after trial fitting them I cant go back to those pissy v belt pulleys
  7. #877
    Dec 2011
    ATL GA USA
    If ask me, i like better the micro belt and thats what i am going to run in my 4TGTEU
    Dont know what i am going to use for the harmonic balancer but something i will come up with when time comes to deal with it!
  8. #878
    Maybe the brd racing one as suggested?
    Ive just had a thought,seeing that the harmonic balancer doesnt need to be retained I might just get an adaptor plate made up inplace of the old pulley and then just get the waterpump gilmer pulley milled down and the center hole bored out to the shaft on the wp!
  9. #879
    Ricey,
    Have a look at the Gilmer drive set up in my TA23 thread. The crank adaptor was made locally. Can't remember the company name but Jim at SAS could organize it for you.
    With the water pump keep in mind there are two different shaft lengths.
  10. #880
    Feb 2011
    south australia
    hey all. does anyone here have a 3tgte alternator there not useing?? i am in the need of one asap im willing to pay for poastage anywhere in australia if some one has the right one. mine has done the regulator in and decided not to work anymore. your help will be verry much appricated.
    1985 ST141 TOYOTA CORONA SR 5SP MANUAL 2S-C
    1985 RT142 TOYOTA CORONA SR 5 SP MANUAL 22R-E
    1986 RT142 TOYOTA CORONA WAGON 5SP MANUAL 22R-E
    1984 TT142 TOYOTA CORONA GT-T 5SP MANUAL 3T-GTE
    1983 AT141 TOYOTA CORONA GT 5SP MANUAL 4AGE
  11. #881
    Jul 2009
    i gave up on finding a new one.
    I read up on putting a ford one on and other models but all have draw backs.
    In the end I got my original one rewound/rebuilt with new reg.
    In saying that, it lasted 4000kms before the regulator had to be replaced as it was a fault bosch item.
    my old ride:
  12. #882
    Feb 2011
    south australia
    ok thanks steeko.
  13. #883
    Feb 2011
    south australia
    hey steeko do you have a part number for the bosh item you used for your alternator??
  14. #884
    Look up the EA ford upgrade. Its easy to do, even I could do it! I have a couple here but dont know which way I am going to go or what will be easiest to fit after doing the pulley upgrade. WIll suss that out in the next couple of days and let you know if you like?
  15. #885
    Jul 2009
    From memory there are draw backs from the ford one, like killing it from high revs? I could call the auto elec if u like? The copper was also rewound.
    my old ride:
  1. 3T Versus 3T GTE conrods
    Last Post: 17-04-2011, 09:39 PM
    Last Post: 15-04-2008, 06:13 PM
    Last Post: 01-06-2007, 01:59 PM
  4. html in the tech section
    Last Post: 28-12-2005, 11:49 PM
