Results 1 to 4 of 4
Thread: 5M-E Auto Tranny Issues
    Corolla Collecter Backyard Mechanic Trent-KE30's Avatar
    Default 5M-E Auto Tranny Issues
    hey guys,
    I got a 5M-E which in putting into my MZ10, now i took auto gearbox off to check a few things and im having difficulty putting the bastard back on, i have put the torque converter on the gearbox spline before aligning the box, and the bastard needs to come and extra half an inch and it just won't go any further. ive tried deburring the dowels and oiling them up etc, any tricks in doing this?
    Also how hard would it be to put a W-40 behind a 5M in a MZ10?
    Cheers Trent
    1977 Toyota Corolla KE30 1GGTE http://www.toymods.net/forums/showth...post7372821977
    1987 Ford Falcon XF S Pac
    Junior Member Grease Monkey johnny blade's Avatar
    Sweden
    Default Re: 5M-E Auto Tranny Issues
    Are the converter realy in the right position?
    1 MS55 - 3 TA47 - 1 MS123 - 1 YR21(SR21) - 1 RX80 - 1 ST165 - 1 JZS160
    I just wonder if the torque converter is really in the right spot. Rotate it a bit more and you might find it slides down on the shaft that extra inch or so.
    As for just fitting up a W40, I really recommend a W50. You'll need the usual crap - pedal box, master and slave cylinders, hard lines, spigot bearing, flywheel and clutch. Can't comment on the tailshaft length but I'd imagine it'll be different. You'd probably just have to replace the front half though if at all.
    W58 would be a better option for a manual conversion since it will bolt right up with factory bits. W40/W50 will require some sort of custom crossmember arrangement.
  1. w50 to auto?
    By dundee230966 in forum Tech and Conversions
    Last Post: 30-06-2007, 08:01 PM
  2. 7m cressy AUTO tranny cooler's....how efficient are they?
    Last Post: 18-05-2007, 12:41 AM
  3. 1jz auto box has issues?
    By pete05 in forum Tech and Conversions
    Last Post: 14-05-2007, 02:13 PM
  4. big trouble little Soarer town - Auto issues.
    By Johnzoku in forum Tech and Conversions
    Last Post: 20-11-2006, 09:01 AM
