Results 16 to 30 of 37
Thread: How many litres per 100 on a 1J
    Gangnam style Automotive Encyclopaedia beatle's Avatar
    Perth
    Default Re: How many litres per 100 on a 1J
    i got about 11-12L/100km on a trip down south recently but i average around 15-17L/100km normaly
    thats an auto jza70
    TRB01J Backyard Mechanic jak's Avatar
    Jun 2007
    if you mainly do highway km's, you would benefit from putting a switch in for the lock up clutch.
    that, + overdrive, we were sitting on 130 on gwh at 2700rpm on the way back from jenolan caves.
    Jak
    '77 RA28 Celica - Repairing Rust...
    '84 AE71 Daily Driver/Race Car
    '91 MX83 - Fastest Standard Turbo 1JZ Powered Vehicle In The World -
    10.74 @124 Mph
    http://www.youtube.com/watch?v=H2ido6yirZ8
    I'm sure you mean 110, which is the speed limit
    maybe my 2gay is not as bad on the fuel as I thought it was.
    Act
    jak who does these switches
    Jun 2007
    sideshow does them.
    but any auto elec should be able to put one in, u just have to supply current to a wire goin to the g'box or sumthin. its pretty simple.
    Jak
    10.74 @124 Mph
    Quote Originally Posted by jak
    What does this switch do? Doesn't the ECU lock the converter when the revs/load are correct anyway?
    No doubt there is some purpose, or people wouldn't bother ...
    My 1JZ MX83 gets pretty woeful fuel consumption too. (I did calculate it, but I think I threw the figures away in disgust). I'm about to do the ECU capacitor replacement trick (which might help) but probably a check of the O2 sensor may be in order as well. (As would a lighter right foot )
    '93 MX83 Cressy with 1JZGTE (now with engineered goodness)
    '85 YN57 Hilux SR5 with 3.8l V6
    '98 ES300 (with gold bits!!)
    + A Corolla and some non-Toyotas
    Western Aus
    $90 of fuel @ ~145c gets me about 300k's.
    Jun 2007
    its better to have it on a switch so u can use it more often than the computer does.
    o/d drops bout 1.5k revs, then hit lock up clutcch and it drops another 1k.
    the switch just supplies 12v to two wires which in turn locks up the converter.
    Jak
    10.74 @124 Mph
    vic
    Great to see a Honest thread about fuel consumption , And the Fact that most turbo 6,s are not that great on fuel around town.
    My 2JZ-GTE gets 10.4 on the freeway and about 15 around town , And thats with nicely cleaned up head ports and matching manifolds.
    Dave
    What would be good to see is some figures from people with aftermarket ECUs.
    With a good tune & respectable A/F ratios I would expect much better figures for both city & highway driving.
    vic
    From my experience you dont anything for nothing , most factory ecu,s will trim as lean as they can on the highway ,Ive tried to lean off a few ecu,s but mostly end up with rough running problems.
    Id guess the only gain you would have with a aftermarket ecu is around town when a factory ecu fuels up a bit rich to stop melting things ( this is turbo of course).
    Dave
    Junior Member Backyard Mechanic pete05's Avatar
    penrith nsw
    [QUOTE=cambelt1]From my experience you dont anything for nothing , most factory ecu,s will trim as lean as they can on the highway ,Ive tried to lean off a few ecu,s but mostly end up with rough running problems.
    I noticed this rough running when i fitted my first fcd, now i tuned the fuel cut out through my boost controller and its much nicer to drive. The 1j ecu dont like the way the cheap fcds lean them out.
    Jun 2007
    it depends, coz if u have an after market ecu, u are probably chasing higher power figures than the average 1j. which would then cost more to run.
    in the trip back hme fro jeolan, id say ours gets about 3km/l around town and 5km/l highway driving.
    Jak
    10.74 @124 Mph
    70L will net me on average 550 kilometers. but thats to dead empty none of this fuel light warning crap
    thats 1660 KG incl driver
    suburban/city driving 50/50 highway/fwy & suburban driving
    320 odd hp
    manual.
    JZA70|R / 12.45 @ 111 mph.
    Jun 2007
    thats awsome.
    u must have a great tune to be getting that with thos power figures.
    Jak
    10.74 @124 Mph
  1. JZA70 and MA70 Specifications
    By twentyEight in forum Tech and Conversions
    Last Post: 18-12-2016, 10:18 AM
