I think you need to stick your car up on ramps & have a look underneath.![]()
3 of the 4 engine mounts are on the gearbox, so using another SW20 box (even the turbo) means no drama there.
The other mount on the end of the engine is most likely interchangable between the motors, if they're not already the same.
If your current driveshafts are only one piece, ie one long one & one short one, I'd be using the split shaft turbo versions (actually you will have to anyway as the gearbox end spline is bigger than the NA versions)
Physically, the motor should just go straight in with no mods.
The wiring on the other hand will need changing.
PS what year is your car, if its a 96 or newer I may be interested in your old 3S-GE...![]()
