Results 16 to 25 of 25
Thread: What oil to put in my 1UZ?
    Default Re: What oil to put in my 1UZ?
    even non-trade the 4A-GE filters set me back $17... some of you people are getting reamed...
    rrp they are like $22-23 from memory
    hmmmmm... maybe the guy gave me a discount... cool, I never asked for it
    Junior Member Grease Monkey 9000rpm's Avatar
    Tasmania
    1UZ oil filters = 90915-YZZD4 RRP should be $23.10
    Z386 equivalent filters 90915-YZZE1 RRP should be $17.60
    4AG + 3SG filters 90915-YZZE2 RRP should be $18.70
    V6 filters 90915-YZZD2 RRP should be $18.70
    the D2 also suits some of the bigger 4cylinder engines (3RZ-FE)
    is certainly not a Automotive Encyclopaedia suss_slide's Avatar
    S.A.
    thanks fellas, might have to pop into toyota sometime next week.
    Now targeting, people who are now targeting!!
    Quote Originally Posted by TooF
    Interestingly I've also been given the d2 for use on 3sgte's (which normally take z386 equivalent filters, I think they are slightly bigger by memory... so it should be interchangable with 4age, 3sge etc
    I am the sun
    you *should* have been given a E2 for your 3sg motor and they are not a z386 equivilent they are significantly longer just the same OD. the D2 has a larger OD then the E series filters and *shouldnt* fit your 3s
    Canada
    Gen 1 3SGTEs take a different filter than 3SGE or 3SFE.
    Gen 1 3SGTE take the filter that has a larger outer diameter.
    i actually realised this after having to goto my storeroom and grab a filter for a mate and i looked at the E2 and it said expcet 165 then a D2 sayus for 165 so i figured it must have been th case
    Last Post: 29-10-2021, 09:49 AM
  2. 1UZ aftermarket ECU option??
    Last Post: 04-08-2011, 08:07 PM
  3. 1UZ VVTI... Wiring questions.
    By MWP in forum Tech and Conversions
    Last Post: 07-06-2007, 03:00 PM
  4. Replies: 23
    Last Post: 29-04-2007, 12:18 PM
