1991 = 3S-FE I guess? timing marks, I guess you're meaning the base timing? I think (from memory) it went [10 | 0 | 10].
hi just need the onwers manual or if someone knows timming marks for this engine model?? could you please help would be appreciated
thanks
Ebb
i mean the marks for the timing belt as it snapped
You just line up the cam gear with the mark on the side of the head and check that the 2 scissor gear marks are lined up. Put the crank on TDC with the mark on the timing gear on the crank and the mark on the oil pump. Put the belt on as usual.
ah. would've been good to put that in the first post.
http://ugbox.net/%7Elance/GT4/Techni...ing%20belt.pdf
section EM50 should help you out a bit.
