If your motor has no blowby then the front seal will be fine , also dont restrict the pcv system . You bore out the little dain hole at the bottem to about 5 or 6 mm i think
The actual reason for the oil pump mod is to drain off excess oil that the original drain hole cant cope with that the oil pump leaks thru its gears.
Dave
