my personal preference is to run a brand new engine in on a chassis or engine dyno. i use up to 100% throttle but keep the revs below 5000 (not using a rev limiter as this can cause bearing damage) and the engine loaded at all times.
if your starting with a fresh ecu make sure you keep a good eye on your afrs as fresh engines dont like to be run rich as it causes bore washing ie the fuel washes the oil off the bores which aint good.
start with a cheap mineral oil (like hpr 30)
i change the oil after 50km, then at 250 and then every 500kms after that till 5k only after that will the engine be clean enough to run a good synthetic oil.
i think everyone has differing opinions on this subject so i supose its up to you, i run engines in hard and dont have probs with it cause as stated in motomans webpage there is a big difference in the way machining is done these days compared to the old.
linden
