It should have a horn dude. In NSW you need a horn to pass rego and i would assume you also need one in QLD. Look for a single wire with a spade on the end at the front of the car. Ive got a feeling they also had a horn on either side but im not 100% sure but either way there should be one wire on at least one side of the car. Check the harness on either side of the radiator and if you find a few single wires with spades on the end then just pull your horn out of the wheel and test continuity between that and the other end of the wire for a definite answer.
