Results 1 to 13 of 13
Thread: windscreen sealent
    custom dont come in a box Domestic Engineer toymotorsport's Avatar
    May 2006
    Default windscreen sealent
    ok guys ive removed my front and rear windscreens to transplant to new body looking for a good windscreen sealent to replace them any sugestions
    FRustrated INdividuaL !! Grease Monkey Rosey's Avatar
    Default Re: windscreen sealent
    Mate my windscreen man swears by "BOSTIK MASTIC SEALER 5614" its in a caulking tube 490 grams Black...
    Cheers Rosey [email protected] Rosey's GT TA22 Celica - 72' Model
    For me its the 1st generation GT's I'd Kill for a 72 GT but since most people don't even believe they exist
    May 2006
    Quote Originally Posted by Rosey
    no idea where a suplyer is do you
    I got my bostik stuff in a squeeze tube from repco/autobahn/supercrap. messiest stuff I have ever worked with, but did a great job as a sealant
    My windows have been sealed with a non-setting rubbery tar type substance.
    Anyone know what that could be?
    Hoppers Crossing
    butyl mastic is what its called
    use kero to clean it off...
    T'ville, QLD
    yeah mastic sealer FTW but mastic sealer in your carpet FTL
    2T out 4A in....
    Quote Originally Posted by toymotorsport
    Wander in to a windscreem fitters shop, most around here will sell you a couple a tubes at the right price.They buy it by the box loads, so will be cheaper than the auto stores.
    cheers Chuck.
    MS51Crown Coupe,
    the guy who did my windscreen used a mastik that came in a semi-solid roll form - basically a rectangular extrusion with the layers of the roll seperated with waxy paper - a lot easier to lay it down in the recessed sections plus you can leave the wax paper covering the stuff until you're ready to put the glass back on.
    no excess stringy, black goop to clean up.
    May 2006
    thanks for all the info guys
    If you are doing the install yourself, have fun. I would rather pay the man his $120.00 to have both screens fitted.
    After he has gone squeeze some sealant between the glass and the seal. Most windscreen fitters do not do this, insisting that the glass and rubber will knit together. I can tell you for a fact the end result without the sealant there is wet feet!
    cheers Chuck.
    MS51Crown Coupe,
    May 2006
    Quote Originally Posted by ChuckLandwehr
    cheers Chuck.
    my windows dont have a rubber seal
    V8 motavation. Grease Monkey 289hilux's Avatar
    Oct 2007
    The window fitter I know uses SIKAFLEX 926 black You can get flat nozzles. make sure you clean the glass and inset to an inch of its life so it will adhere properly.DON`T drive the car for at least 12 hours.
    You will also need the rubber blocks to sit around the recess to situate the screen corectly.
    Injected 5.0L FORD power in HILUX is the only way forward!
    See my ride here: http://www.toymods.org.au/forums/sho...246#post601246
  1. Replies: 4
    Last Post: 13-03-2006, 09:35 AM
  2. Rubber mounted windscreen installation - without the heartache
    By o_man_ra23 in forum Tech and Conversions
    Last Post: 17-01-2006, 10:55 AM
  3. KE70 Windscreen - Alternatives to Chrome Trim
    By WDE_BDY in forum Tech and Conversions
    Last Post: 31-12-2005, 03:48 PM
