I then traced out the mounting holes onto the cardboard and also checked them for accuracy with the vernier calipers. Once i had established they were 95mm apart i used a hole punch to punch the holes in the cardboard.
once i had checked everything over and was happy with it ( you can never check too much)
I then drilled the holes in the plate and started cutting the shape out.
With the shape cut outnow i could bolt the caliper on using both the caliper mounting plate and the spacers to check everything out.
This is a photo of the finished product ready for a coat of paint..-----I sand blasted the mount so it was clean and could be painted.
This is the finished product all bolted up and brake line installed.
Thats basicly it!!
