have you disconnected battery then tried again a bit later?
mine occasionally does that... go to start it, and it just dies in the arse... nothing, even the fuel pump stops. take off negative battery terminal, make sure it's seated properly, then it seems ok.
I did have a problem with the crappy isolater i've got on the positive terminal, where it would stop powering the important things at rather inopportune times, and the symptoms were just as you described.
do you have some wierdo immobliser that's interfering?
when you say you can't get ecu codes, how do you mean it just wouldn't work... is there no diagnostics connector or something
