Thanks, will do that then.
Is it the rust converter that makes a layer that prevents the metal rusting, or does the etch primer do that too? Or does the etch primer only help the normal primer stick onto the metal?
So I'm just wondering if I sand all the rust away, will the etch primer help seal the rust away, or will I still need to use rust converter to kill all the microscopic bits of rust.
Like say if I had a rusted door or bootlid and i sanded it away to the metal, can I coat it with etch primer, then acrillic primer then paint + clear.
Or do I have to use rust converter, and the rust converters that I know of are ones that are meant to be applied by brush, so cant be sprayed?
