Its been about 9-10 months, since i've touched my 22.... Bought a house in the last 8 weeks, and just brought the car to my new place 3 weeks ago.. Now its time to get stuck back into it, in between house renos...
My next step is to re-plate and fix all the rust cut outs, im thinking of buying a welder...
My question is...
is a gasless welder good enough to do the job?
I've found two
1) at repco MECHPRO Portable 100amp gasless mig welder for $299
2) at bunnings OZITO 90amp gasless mig welder for $299
Which one would be better?
If u guys could please help me or give me a few ideas, i really want to get this car finished this year.....
Thanks
A half saecond pull on the spray gun trigger with the gun held about 200-250mm from the test piece should give you a elipse about 200mm high and about 35mm thick in the middle, the paint should almost be at the run stage, but not quite. When applying the paint to the car, position your gun at 90 deg to the panel again about 200-250mm off, squeeze your trigger before you actualy get to the panel, and release after you have reached the end of the panel, You must travel slow enough to get a wet film, but not so slow that the paint/clear runs. (you should practice this on your test panel) Your next pass has to overlap the previous pass by 50%. Your wrist must be locked in the straight ahead position, no rotating allowed, this way you maintain a constant angle and distance from the job, which results in a very even coverage of the panel.
