Page 3 of 6 FirstFirst 12345 ... LastLast
Results 31 to 45 of 78
Thread: 1jz Bolt ons
    Default Re: 1jz Bolt ons
    what do you classify as expensive? thers a fair bit of materials that go into them not to mention a minimum of 8hrs labour to build them to suit a car.
    btw the design of his aint that great as it restricts the wastegate too much.
    and yes elmo is correct its the massive heat buildup in the stock y pipe that causes problems coz none of the cars ive done dumps on have had a turbo failure to this day.
    linden
    if i wanted around 240rwkw id keep the twins
    IIRC they are close to $800. More generic ones ie. without seperated wastegate section seem to go for $400ish. So double the price for the better ones is expensive IMO.
    Plus the fact that you can put that money towards a single conversion and not have to deal with working on the stockies again
    QUICKEST 1JZ'S IN OZ
    Or keep the stockies and go as hard if not harder than those expesnive or even " budget" single conversions without any Legailty issues either!!!
    OMGZ did i just Type that!!! Hahahahahahah, couldnt resist!
    11.72 @ 116.7mph = Quickest Stock Turbo Jzz30 series Soarer And 1st into the 11's WOOOT!!!
    Still going good
    http://www.youtube.com/watch?v=tc_7aRUGshw
    You'll keep mate
    You know your car is a freak. "most" stock turbo cars can't do the shit that yours can.
    is a semi-motivated Domestic Engineer 1JZ~lux's Avatar
    Hmmm. If dump pipes for the twins are this expensive, maybe its not worth sticking with the twins. I'll shop around and see what I can find.
    Petrol is for washing parts, alcohol's for drinking but NITRO IS FOR RACING!
    My pictures, Returning some time in the distant future.
    RN85 Hilux + 1JZ-GTE = 298.0HP @ 14PSI -- 60' 1.956 ET 13.775 MPH 99.49
    Project Korruption - Stage 1: The Resto. KE35 Corolla Hardtop daily driver
    TRB01J Backyard Mechanic jak's Avatar
    Jun 2007
    Sasha from canak autosports does a nice set of dump pipes for around the $600-$700 mark i think.
    twin dumps made for a cressy 2.5" all the way to the cat. similar setup to mine.
    pete05 has a set on his jzx73.
    Jak
    '77 RA28 Celica - Repairing Rust...
    '84 AE71 Daily Driver/Race Car
    '91 MX83 - Fastest Standard Turbo 1JZ Powered Vehicle In The World -
    10.74 @124 Mph
    http://www.youtube.com/watch?v=H2ido6yirZ8
    sir Grease Monkey
    tasmania
    with these twin dumps where do you blokes put the o2 sensor ,on one of the dumps or further down where both pipes collect. i was thinking that i could knock up a kit with all the flanges and heavy wall pipe fittings ,then only semi finish it so it could be re configured to fit different model cars.another bit of trivea ,with a bit of work a 2jzgte ehaust manifold will fit a 1jzgte nicely. cheers. bigwad
    my custom dumps the o2 sensor was put in one of the two pipes just before the collector. however i no longer use the sensor so meh.
    JZA70|R / 12.45 @ 111 mph.
  8. #38
    What do you use instead of the O2 sensor??
  9. #39
    Jun 2007
    same with me, no need for it at all, just block it off with a short bolt.
    Jak
    10.74 @124 Mph
  10. #40
    do the micro lebs not use an o2
    The boobs are back
  11. #41
    nope. No open loop fuel tuning so not required. You can hook it up for some inaccurate afr datalogging if you want though
  12. #42
    either my power fc didnt like the o2 sensor or the o2 sensor didnt like the power fc...
    with the power fc using the o2 sensor for closed loop, idle and cruise would fluctuate and hunt around. so ive turned it off which means its not being used.
    narrow band o2 sensors are over rated
  13. #43
    Western Aus
    Quote Originally Posted by chris davey
    Lew Radbourne from soarer central makes some good dumps but they are expensive.
    neonasty: same reason I went single. I thought my twins were gone (apparently not as Wilbo is still using them ) and decided that I never wanted to go through that hassle again. Mine is harder than usualy as I have a steering box there. Basically had to half disassemble the rear turbo to get the bastard out. NEVER again!
    In saying that, I did have some serious issues with my old 4" dump pipe getting that in and out as well
    ive heard on a few occasions from people that have bought Lews dumps would have rather gone with china.
    having seen them, im glad i went with china too.
    at $300 for the dumps, front pipe (to cat) and all gaskets, im happy.
  14. #44
    On the note of O2 sensors, I'm thinking of this for tuning and monitoring speed (stupid Hilux only goes to 160) and stuff.
    http://www.plxdevices.com/products/r500/
    Any opinions on PLX Devices?
  15. #45
    Junior Member Backyard Mechanic pete05's Avatar
    penrith nsw
    Hey all seem as there is all this 1jz goodness talk goin on and lots of talk about dyno figures, im just wondering how everyone dynos there autos? I took it to a place the other week and they dyno guy could do a proper power run in 3rd gear, every time he tried it would just shift back to second and spin the rear tyres. what gives?
    If you follow the link to my ride, on the second page there is photos of canaks dump pipes, that i have fitted for those interested.
  1. 1JZ vs 7M alternator useful info and pics
    Last Post: 22-06-2009, 05:10 PM
  2. 2JZ Water Pump onto 1JZ
    Last Post: 28-10-2008, 11:33 PM
  3. JZX81 1JZ: Analogue Dash Wiring
    By mamba in forum Engine & Driveline Conversions
    Last Post: 19-05-2007, 05:04 PM
  4. 1jz to 2jz
    By HIZOKU in forum Tech and Conversions
    Last Post: 30-11-2006, 07:52 AM
  5. 1jz and Haltech e6k
    Last Post: 10-10-2006, 05:25 AM
