Results 46 to 60 of 78
Thread: 1jz Bolt ons
  1. #46
    Western Aus
    Default Re: 1jz Bolt ons
    (edited bad advice )
    michael beetle copped 299.5rwhp through an auto
  2. #47
    Junior Member Backyard Mechanic pete05's Avatar
    penrith nsw
    thats what i was thinking but doesnt that affect the oil pressure in the gearbox?
  3. #48
    disconnect the kickdown cable and it wont shift down when you give it boot.
    don't do this.
    pete05: yes it does. Start at higher speed and less TPS early on.
    QUICKEST 1JZ'S IN OZ
  4. #49
    Quote Originally Posted by JZA70 R
    either my power fc didnt like the o2 sensor or the o2 sensor didnt like the power fc...
    with the power fc using the o2 sensor for closed loop, idle and cruise would fluctuate and hunt around. so ive turned it off which means its not being used.
    narrow band o2 sensors are over rated
    Basically answer to your problem is it's not tuned correctly. Get your hands on a stock 1jz-gte map from apexi, you can find them if you have fc-datalogit and use there map area for idle and below idle, fixes all problems related to poor idle or decel cut outs. Only copy the fuel correction map, not the base map.
    As for narrow band o2 sensors they're meant to move back and forward, that's how they work.
    This is a log of narrow band o2 sensor voltage between 0-1volt using fc-datalogit. This is what it does when you're driving normally from a set of lights. The average of that is around 0.48volt, which is approximately 14.6-14.7 afr.
    Using open loop just takes the injector times from the base map which could be fucked to all hell for all you know on ratios. You can't tell until you stick a wideband o2 sensor up the tailpipe. However saying this when they are tuned, the tuner is suppose to tune the base map to 14.7 at all potential closed loop points or at least as close as possible, and the closed loop mode with narrow band is suppose to clean it up and make it just like factory.
    I actually hooked up a wide band now that has a narrow band emulator for the power fc, but logs the wideband thru the fc-datalogit. Get to see the exact afr now. I usually see between 14-15 when cruising around with o2 feedback on. When off however, it doesn't go up and down, instead it can sit on one ratio, and changing rpm or pressure changes the ratio. I found my tune is between 13.3-15.3 on this, and my one was a 6 hour tuning session.
    Toyota Corolla Conquest 2003 black manual 1ZZ-FE - Daily
    Toyota Soarer GT-TL 1991 white auto 1JZ-GTE - [email protected] 1.587 60'
    My JZZ30 SOARER
  5. #50
    The problem was when i was running the base map. The tuner turned off o2 feedback because he either thought the o2 sensor was stuffed, or couldnt be assed trying to rectify the fluctuations.
    JZA70|R / 12.45 @ 111 mph.
  6. #51
    Tuner is suppose to turn it off, it's the only way to tune it correctly.
    My JZZ30 SOARER
  7. #52
    Junior Member Backyard Mechanic slipway's Avatar
    brisbane
    at $300 for the dumps, front pipe (to cat) and all gaskets, im happy.
    eldaro i got these dumps what boost do you run and are they heat wraped i wanna heat wrap mine but dont know if the stainless will crack with more heat.
  8. #53
    Forum Sponsor Conversion King
    and it will fry the clutches, but feel free to try it in yours.
    linden
  9. #54
    penrith nsw
    Im not interested in destroying a gearbox thanks
    what speed are people doing them at? from about 80kph onwards?
  10. #55
    With the Power button OFF... Dont use WOT until after 110km/h as this is the HIGHEST kickdown point from 3rd to 2nd.. After 110km/h it wont kick down!
    We use this method for Dynoing my car, and also used it on all the TT's and V8's on our Dyno day without a drama
    11.72 @ 116.7mph = Quickest Stock Turbo Jzz30 series Soarer And 1st into the 11's WOOOT!!!
    Still going good
  11. #56
    penrith nsw
    Quote Originally Posted by Dieseltrain
    Cheers will give it a try when i get a new intercooler in it
  12. #57
    Western Aus
    Quote Originally Posted by slipway
    mine arent wrapped, but they have turned a pretty purple color
    i also run no heat sheild, boost is between 11-12 psi.
    will edit bad auto advice now
  13. #58
    Hide Yo Kids Hide Yo Wife Carport Converter hamgatan's Avatar
    on a side note eldar/todd ...where do we get heat wrap locally?
    JZZ20 1988 Soarer GT Twin Turbo
    1JZ-GTE + R154 + LSD | Black Knight Still being Assembled
  14. #59
    Western Aus
    Ezra has a metric butt-load spare, ask him?
  15. #60
    sell it at work for $8 per meter. you can buy it off ebay cheaper. a lot cheaper.
  1. 1JZ vs 7M alternator useful info and pics
    By Ribfeast in forum Tech and Conversions
    Last Post: 22-06-2009, 04:10 PM
  2. 2JZ Water Pump onto 1JZ
  3. JZX81 1JZ: Analogue Dash Wiring
    By mamba in forum Engine & Driveline Conversions
    Last Post: 19-05-2007, 04:04 PM
  4. 1jz to 2jz
  5. 1jz and Haltech e6k
    Last Post: 10-10-2006, 04:25 AM
