Results 31 to 45 of 48
Thread: 4AGTE Buildup
    Backyarder! Grease Monkey
    Default Re: 4AGTE Buildup
    Quote Originally Posted by TC1600
    THIS is the man to listen to about turboing a 4AGZE, his user name says it all. And check out his ride thread.
    you mean the laser that i built with 177fwkw at 13psi? that was stolen so maybe i wouldnt want to have it in my members rides...?
    how bout dont be such a cock and realise that your epenis isnt as big as u wish it was.....
    things are all differant, if i wasnt sitting in the car on the dyno and someone told that it made that much power, i wouldnt have believed them either. but these days with tuning, technology and research things arnt the OMFG that cant happen.... why? because no one has tried it?
    pull ya head in.
    S.A
    Quote Originally Posted by cri_ag
    i have 190rwkw with 440cc injectors, stock fuel pressure, bosch 910 pump. il try and find out what duty cycle.
    Post the sheet im keen to see it !
    Cuzzo : Some ecu's give an indication to what the injector is operating at
    Riiiiiiiiiiiiiiiiiiiiiiiiiight all he was saying is that mr 30psi4agte knows his stuff.
    Junior Member Grease Monkey KOV51's Avatar
    Quote Originally Posted by slow laser
    pull ya head in.
    Dude this is my thread and you are filling it with banter please no bullshit or just post elsewhere thanks
    what rpm was the 190kw at?
    it's easy to make more power by changing cams and bumping up rpm (if everything else supports it )
    there is no magic with how much power engines make.. they just get closer and closer to the maximum output available from the fuel, the capacity, the rpm, and the boost
    8200 was the rev limit, but it made peak at 7900 or so judging by the speed on the dyno.
    the power didnt taper off, just leveled so no point reving it any harder.
    What turbo are you using mr cri_ag?
    im using a gt2871r
    Quote Originally Posted by 30psi 4agte
    ill ill scan the printout when i get my new scanner hooked up.
  8. #38
    S.A
    sweet mate.
  9. #39
    Forum Sponsor Conversion King
    cri ag's car does have 190rwkw but i think the duty was gettin near max, ill ask brett for a sheet on mon if craig cant get his up (no pun intended).
    when you comin to pick the exhaust up for the spoonta?
    linden
  10. #40
    personally stick with a t28, leaves u a good base flange that u can upgrade to....
    as opposed to a td04 which wont make much power, and leaves u with a awkward flange thats hard to upgrade from....
    while i prefer gt series stuff its easy to upgrade a td04 you can buy a 500hp bolt-on for rex's which is more than the average 4agte owner will ever want.
    td04's are cheap so why not
    linden
  11. #41
    Im looking at doing this soon road runner. Do you suggest what model upgrade? Its a VF**?? model number i think?
    I want around 240 atw
  12. #42
    Feb 2007
    Timaru
    I made 200kw on my 20V 4agte using 100% genuine toyota parts, and ran it a race car for a year no worries.
    Was a s/h engine fitted with new
    Headgasket
    Rod Bolts
    Rings
    Head studs,
    all genuine from toyota
    I put a s/h set of AE101 GZE pistons on the 20V rods,
    and has a non BB T28 on it.
    Never had any reliability issues with it.
    - KE70 Corolla Dx -
    - 500hp+ 7AGTE 20V turbo -
    - MRS/Hayabusa turbo **sold**
  13. #43
    Junior Member 1st year Apprentice klusio's Avatar
    Tasmania
    I only made dyno sheet proven 125kw with my TD04 from a 2000 model WRX
    AE92 bottom end bit port head with smoothed throats 440cc injectors, RWD intake manifold microtech LT10s on 14psi using a GFB bleed valve boost seemed to taper off.
    Think the tuner was very conservative
    Im looking to upgrade and would like 180kw to keep the nissans hounest in the local drift comp.
    Ideas?
    Cheers Kieran
    AE86 4a turbo - current project
    KE20 shell on blocks - project on hold
  14. #44
    You should definelty be making more than that! You should be around 150-160kw atw.
    Is it running rich?
  15. #45
    Feb 2007
    Timaru
    Quote Originally Posted by klusio
    Ideas?
    Bin the TD04
    Go for a Nissan T28 type off a Silvia SR20 or better, a GTiR Sr20
    or a TD05 off an Evo type 4G63
    - KE70 Corolla Dx -
  1. nitrous & 4agte
    By caibs in forum Tech and Conversions
    Last Post: 16-08-2007, 10:46 AM
  2. 4agte Info
    Last Post: 16-03-2007, 08:15 PM
  3. GZE Alternator Question for 4AGTE Conversion
    Last Post: 29-06-2006, 06:29 PM
  4. Getting 4agte conversion done... where in perth shall I go?
    By AE101LEV in forum Tech and Conversions
    Last Post: 25-05-2006, 07:59 PM
