Results 16 to 30 of 52
Thread: 3SGTE Fueling/tuning issues and possible tradgic problem
    Forum Sponsor Conversion King
    Dec 2006
    Default Re: 3SGTE Fueling/tuning issues
    Quote Originally Posted by ONCE-NA
    Does the 3sgte standard have duel nosel injectors? Could this be a problem the single pintel ones in there now squirting against the divider between ports? (They are 8 port yeah?)
    it can cause emissions probs and wall wetting but not bad enough to cause these kinds of probs.
    linden
    Junior Member Backyard Mechanic ONCE-NA's Avatar
    Nah! Havent checked cam timing! I should, where can I find the specs for that? Valve clearance's wernt perfect but okay enough...
    Dec 2006
    put the crank at 0 and check the marks on the cam gears, they should line up with the marks on the cover behind the gears. should be some pics around here (toymods).
    do this first as otherwise you'll be chasing your tail for no reason.
    linden
    Okay cool thanks man
    Yeah they all line up! Even leaning it out to high 12's at higher RPM causes rougher running and popping etc out the exhaust. And I have found another problem that may or may not be linked, stand by for pics...
    There is a crack at the side of the head, its hard to describe the location (gotta wait for my g/f to get home with the camers) The crack was repaired (welded) at some stage before I had this motor but it apears to have opened again, we only noticed this as a little oil seeped onto the exhaust manifold flange and smoked up. I'm thinking maybe the crack extends further than it looks into combustion chamber or exhaust port) and it could explain oil vapor comming out of the cam cover vent and (what I think is excessive case pressure when I remove the oil cap when running. Having done a compression test today all cylinders were even 170 psi except for number 1 which was only 5 psi down and well within tolerance. Though this crack is near number 1.
    Not in the diner Alf! Conversion King RyleyMA61's Avatar
    Default Re: 3SGTE Fueling/tuning issues and posible tradgic problem
    thats horrible man, gw told me... real sorry to hear about that! i hope that someone didn't do a dodgy on you
    Dec 2006
    hmmm, not sure dude if your only down 5psi it shouldnt make that much of a difference.
    what do you call excessive case pressure? if you hold you hand near the cap you will always feel big pulses, try sealing the cap with the palm of your hand and if you only feel pulses it should be fine but if you feel it trying to push your hand off with pressure built up then there is something wrong.
    id really have to see what its doing to give more suggestions as im stumped.
    linden
    The g/f left the camera at her dads place, will get pics 2moz, the cam cover is off atm so I won't run it 2nite, but i'm pretty sure it was a hand pusher not just a pulser, will check again 2moz but I'm too tired and disheartened to be bothered now.
    I rekon my best bet would be to source another head, gen 2 or even better a gen 3 if they are directly interchangeable, and swap the cams and maybe the valves and springs etc. seeing as this head has been repaired once before and has cracked again and I don't trust it at all I want to get something quick and get the dam thing going and going right.
    Dec 2006
    unfortunately the manifolds are different but if your after a gen3 send me a pm.
    linden
    Default Re: 3SGTE Fueling/tuning issues and possible tradgic problem
    Nah thanks man, although as I understand the gen 3 to flow a lot better I don't want the hassle of changing the manifold flanges at this stage. The car has been off the road way too long and I just want to get it going asap. So looks like I will chase another Gen 2 head.
    Thanks anyway
    Was this the 'built' motor or the old stockie?
    Junior Member Grease Monkey The GW's Avatar
    Ballarat
    this really sucks man, really really sucks.
    justen to answer your question because rod is at work: this was the 'built' motor that was supposedly fully rebuilt etc. I went with rod to get it from nsw and was there yesterday when we found the crack in the head...
    1984 SA63 Celica - RIP , 1979 Ford XD - The Lunar Lander
    1972 TA22 Celica - Project Car ,1986 ST162 Celica SX - Gone
    1985 RA65 Celica - Me & ryleys rally car
    1974 TA22 Celica - Current project, 1972 TA22 - Wetish
    No probs, i know nothing of the built motor. I did all my work with the original stockie which was untouched.
    Ballarat
    ah ok, dont have a spare gen 2 head layin round you wanna sell do you?
  1. 3sgte Limits???
    By Douglas Black in forum Tech and Conversions
    Last Post: 30-11-2013, 10:33 PM
  2. 3sgte and 4agze standard weights?
    By Taxi>Maxi in forum Tech and Conversions
    Last Post: 20-03-2006, 06:55 AM
  3. Serious 3sgte issues. codes 51,14. need help!
    By Aust162 in forum Tech and Conversions
    Last Post: 09-02-2006, 07:13 PM
  4. 3sge - 3sgte CAS - interchangable?
    By Steve M in forum Tech and Conversions
    Last Post: 20-12-2005, 08:15 PM
