Results 31 to 45 of 48
Thread: Max HP on Stock 1J injectors
    May 2007
    Default Re: Max HP on Stock 1J injectors
    Quote Originally Posted by Dieseltrain
    Muziiz.... How do you know its not running rich? Do you have a Wideband Sensor installed and can monitor it at all times?
    I dont have wideband only the autmoter a/f meter wich when cruising is reading stoich.meaning the air fuel ratio coming out of the turbos is pretty much spot on.
    not only that I get very good fuel economy too to support this.
    The general rule that I heard is that 5cc = 1HP so if the standard injectors are 390cc you will max out at 468HP (78HP per cylinder)
    W.A.
    Quote Originally Posted by 1JZ~lux
    well quite obviously this theory would be my preffered option, but some how i really cant see the stock injectors supporting 468hp.......which is a dam shame haha.
    Chris i agree with wot you say, to get the max out of my turbos im going to need a proper upgrade not a temporary one. Basically im not ready to make that decision to do a big upgrade just yet, so really i guess the only way is going to be put it on the dyno and kep upping the boost until it gets too lean for my liking.
    16psi SHOULD be enough for my liking, which should also get me over the 300hp quite easily as ive already made 297hp on 13.5psi
    Quote Originally Posted by Wildsupra
    Todd you have made 313hp on stock injectors yeah? Can you tell us what duty cycle is shown on your power fc for that that 313figure?
    320 rwhp which is backed up with 110 mph on the strip. Power FC reports 100% injector duty cycle. However atm im convinced the power fc cannot drive the standard injectors as hard as the standard ecu. or in otherwords 100% on the pfc isnt 100% at all.
    JZA70|R / 12.45 @ 111 mph.
    W.A.
    Hmm thats interesting then.
    Time will tell, might need to hook up a dyno run at ya mates place in the near future to see wot this mines ecu is doing fuel wise i'l stick my walbro in first.
    Western Aus
    leaning out on dyno may be due to the 1986.5 7MGE fuel pump running a 297rwhp 1J...
    i know Adam/Pimpin_1JZ got alot less than other people from stock injectors before he had to upgrade, so i think it depends on how you measure it etc.
    id expect 320rwhp on the mines without issues, any more and you'll have to add a safc/e-manage, if you dont like them, microleb etc.
    Elmo.
    Hey, I'm going to get a set of 2JZ-GTE injectors from the wreckers (will get cleaned and flow tested). What colour are the injectors and what's the part number for them so I don't get ripped off?
  8. #38
    Grey topped. Not sure on the part number. They look nearly identical, just grey, and I think the nozells are different but I can't remember the differnces and don't have them in front of me sorry.
    Malicious
  9. #39
    468hp at the crank he is talking about wildsupra, not wheel horsepower
    8.3 et PB 169 MPH PB
  10. #40
    Show Us Your Tints Carport Converter Soarer_D00D's Avatar
    Ive made 365rwhp on stock injectors man. I am running a Wolf3D, so that may count for something, but stock injectors, just with a lift pump surge tank and a 600hp pump.
    No fuel pressure regulator or anythhing.
    Quote Originally Posted by eeeyan View Post
    yeah jump start a planet sort of torque
  11. #41
    328hp @ 18psi on stock injectors with Walbro fuel pump for me. Backed up with a 12.3@111mph at the strip.
    Not sure if the walbro raises the fuel pressure, I'm still running the factory fuel reg.
    Dyno'd on the weekend at 20psi and still had AFR's in the high 11s in the top end of the rev range. So there is fuel there for probably 360rwhp safely (on my setup at least).
    244rwkw / 328hp @ 18psi
  12. #42
    I have an unknown lift pump, custom surge tank, Bosch 044 pump (200L/Hr at 5Bar) and default PowerFC tune and the other day I got the injectors to 82% at 0.6Bar.
    I'll be installing 2JZ-GTE injectors and a Turbosmart 800Hp regulator ($260 + fittings & pressure gauge) then getting the PFC retuned (by Matt Spry at Nerang GC).
  13. #43
    W.A.
    365 on stock squirters would also be nice....might be in for a pleasant surprise when i start upping the boost then
  14. #44
    Arent the 440's Pink?
    11.72 @ 116.7mph = Quickest Stock Turbo Jzz30 series Soarer And 1st into the 11's WOOOT!!!
    Still going good
  15. #45
    Correct me if im wrong, but doesnt having an aftermarket computer such as my wolf, double the injector duty cycle because its setup to squirt on two settings instead of one. I know nothing about ECU's, this is just very breifly what my mate has told me. All i know is that they were running close to the limit on 365hp atw, probally might just see the 400hp mark, but i doubt any further then that.
  1. cleaning your injectors
    Last Post: 12-01-2012, 02:51 PM
  2. Aftermarket engine management and injectors
    By benjamin in forum Tech and Conversions
    Last Post: 14-05-2006, 01:05 PM
  3. injectors for teh p00 motor?
    By RyleyMA61 in forum Tech and Conversions
    Last Post: 20-11-2005, 07:20 PM
