Page 1 of 4 123 ... LastLast
Results 1 to 15 of 48
Thread: cleaning your injectors
    jay zee zee thir tee Carport Converter HAVABEER's Avatar
    Default cleaning your injectors
    hi i'm thinking about taking out my injectors from my 3s-ge and giving them a clean. problem is i'm not sure how and the place locally wants to chagre an arm and a leg for it.
    should i just try some of those "injector cleaner in a bottle" first?
    how do these places actually clean the injectors. do they soak it in something, i remember reading some where that they take the injectors out and pump fuel through them to clean them.
    any help is appreciated.
    Default Re: cleaning your injectors
    How much are they charging? Usually they flow test them, then pump cleaning fluid through them, then flow test them again. Sometimes they also use an ultrasonic bath.
    think it was like $140 - $150 for all 4.
    was just hoping there was a way to do it at home. but from the searching i've been doing dont think there is
    tasmania
    that's probly including labour. if you were to take them out yourself you'd save probly $60.
    your probly just better off to put a bottle of injector cleaner through it if your not sure of what your doing.
    Junior Member Grease Monkey ira11y's Avatar
    its usually about $20 each if you pull them out yourself and take it to them, call up some of the mobile injector cleaners and ask how much if you take them down to there shop. if your in the hills district send me a PM and ill give you the name of a place close by that will do it.
    Cheers Michael
    Opinions are like assholes, everybodys got one.
    vic
    33 retail inc gst per inj is the normal rate these days. The cleaning machine must be a modern one tho
    Petro-Ject in townsville here charged me $64 to clean 4 injectors, including all new seals, and they did a flow test and a pulse test. Take it to an injection specialist, and remove/reinstall them yourself if you want it done for a similar price.
    Yeah, they flow, pulse, and ultrasonic clean it...and also replace the seal..
    Provided that you take the injectors off yourself, itd cost $60 for 4 injectors...
    Makes a big difference compared to just using the injector cleaning bottle...i used it...didnt feel satisfied..following weekend had the injectors cleaned and oh boy there was a big difference!
    ok thnx for the advice i'll call some places and ask how much if i take them out
    Toyota traitor Automotive Encyclopaedia GBC_069's Avatar
    hey guys, any sydney places that you have had experience with for a good price ! ?
    i am hornsby way , dont mind travelling to a place, if its 60 bucks for all 4 i am there !
    NOW - 2002 WRX STI - WRC Blue 180awkw @ dyno day 20
    WAS - 1991 GT4 GRP A no. 68 153awkw, 13psi @ dyno day 18
    WAS - RED ST162 JDM 86kw @ dyno day 12
    S.A
    Quote Originally Posted by HAVABEER
    The injectors are cleaned by placing them in a cleaning solution and putting a ultra sonic sound wave through the solution. This will shake / remove any build up of deposits in the injector . As it has been stated they will then be flow checked to insure that they have a clean / even spray pattern and that they flow the same amount of fuel over a certain period of time ( usually a min )
    Junior Member Domestic Engineer NeoNasty's Avatar
    AH fook.
    I puled mine out myself and took it to Ezy clean?.. Something like that. 120 it cost me. Inc GST. Expensive as a mofo.. and the friggin things were almost perfect anyway. *shrugs*
    Least I know they are good now.
    PS. They were a slut to pull out.
    I used that iinjector clean in a bottle and it did help. one bottle does 3 tanks, but I used the thing in about 2 quater tanks. Worked good. I suggest dp that first.
    HZJ75, RS41, JZZ30
    Quote Originally Posted by cambelt1
    Damn I don't beleive it... A realistic price quoted on the Toymods forum
    Injector cleaning when done properly requires a flow test before they are cleaned, an ultrasonic bath and then a flow test to ensure they are even. The correct cleaning solutions are rather expensive and SINGLE USE ONLY. Add the cost of the solutions (for all 3 tests) and the time it takes to opperate the machine, the purchase price of a high end injector cleaner and if you think its financially viable for anyone to do the job properly for $15 an injector you should up your medication.
    Around $35ea is indeed the going retail rate. ($27.50 trade )
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
    $30 per injector at my local place, but $16.50 trade price.
    EDIT: and between me and nathan we've had about 40 injectors cleaned at this place over the last year. Always come back with new seals, and a verbal report on how they compared to each other ("A couple were 15% down")
    $25 is their retail Cruz. I asked before I made them give me them for $16.50. As he said, they always come back looking like new.
  1. Cleaning injectors, 1JZ-GTE. Advice please.
    By TTMX83 in forum Tech and Conversions
    Last Post: 25-02-2006, 09:15 PM
  2. mechanical specs for 4agze injectors
    Last Post: 04-01-2006, 01:05 AM
