Well fistly the solenoid works by pulling the catch mechanism away from the lock and then allows the boots spring to lift the boot up meaning you will probably have to mount it right where the catch is meaning it will be quite visible. In mounting the solenoid you will probably have to get two nuts welded onto the boots frame so you can bolt it to it. Alternatively you could run a cable and then mount the solenoid under the parcel shelf or somewhere else more discreet.
