check your ecu for error codes, then check your timing with a timing light (it should be 10deg BTDC) the timing belt might have slipped a tooth or be damaged
other than that it's most likely a AFM or tps problem (that said one a 3sge will run with the tps unplugged anyway)
is it a 3sge or a 3sfe?
