Results 16 to 21 of 21
Thread: 3S-GTE Block Variations
    Default Re: 3S-GTE Block Variations
    Quote Originally Posted by dave368
    Block B looks identical to the 3sge Redtop Beams motor that I stripped down and are using in my KE25 3sgte beams conversion.
    It has oil squirters from the factory and if you want to save some weight and aren't using some of the bosses, grind them off. We saved about 250grams (which isn't much but everything adds up) in about 4 or 5 bosses that we don't need in the race car. Its also weight that is right out the front of the car.
    Dave
    Your Red Top Beams has a Banjo Oil Feed Hole?
    Some how I don't think so...
    ([][][]II--LT--II[][][])
    Quote Originally Posted by twentyEight
    The small white circle on the exhaust side of block B is an oil return line from the back of the head to the LHS of the block (about 100mm from the rear and about 80mm up from the bottom of the block) . I thought it was unusual when I pulled the motor down myself but when you consider the number of stories that you hear with the head being full of oil and nothing in the sump for the pump to send back up, you can understand why toyota fixed this problem. i.e. its an external return even in NA guise. We decided not to use this as it would only really suit as an oil return if you have a high mount turbo and mine is a low as you can get it without hitting the rail.
    The oil feed that we used was from the oil filter that has a custom fabricated spin on adapter to feed oil from the oil cooler. We simply cross drilled a bolt to feed the outside of the oil filter boss and then went directly to the turbo and pressure sensors. If this was for a street car, I'd look at tapping the main oil gallery at the back of the block in the similar position to where the factory puts it on gen1 blocks (like the other block photographed). I can't remember if the large bolt in the white circle actually hits the oil gallery or not.
    BTW its now not even close the how it came from the factory in the configuration that we are using it in including removing the oil pump and water pump from the cam belt drive by using a 2Jz timing belt (dry sump and electric water pump before you ask) .
    If you decide to take it from the back of the head in a RWD configuration, make sure you leave at least 25mm of clearance to the firewall as I have seen a motor in a KE35 move that much with rubber mounts and it destroyed the fitting and therefore the motor.
    Junior Member Grease Monkey medwin46's Avatar
    Hey guys,
    I have finally brought home the 3S-GTE that I purchased a few months back and I have noticed a few differences between the 3S block that's been bored and honed, and a spare 3S block that I also have...
    Both blocks have the holes for the oil squirters, so they're both 3S-GTE blocks (as far aas I'm aware off), but the block that has been bored and honed is missing the oil feed hole for the turbo, and has some extra mounting holes which I'm hoping will assist with RWD mounting...
    Anyway, as they say, "A picture tells a thousand words...", so here's my 4 thousand word essay!
    Inlet side - Block A
    Inlet side - Block B
    Exhaust side - Block A
    Exhaust side - Block B
    How am I going to feed the oil to the turbo???
    Block A looks to me to be an NA 3sge, where block B is a 3SGTE, i know because i have 1 of each sitting in my shed and they're exactly the same!!
    Adeladie
    My Gen2 (SW20) 3sge has all the mounting holes for RWD engine mounts. So that would make block A be the N/A one.
    Also i thought all 3sgXX has another fitting on the block on the exhaust side for another pressure sender or oil feed? As at work i have used it to test for oil pressure in the block not the head as the head is too late to find out if you have none.
    Soif thats true wouldn't you be able to take your turbo oil feed off of that? And have a drain back into the sump?
    Edit: Just looked on my 3SGE and theres no fitting on the exhuast side for an oil feed. Might and just be on 5SFE's
    N/A 3SGE KE70 on its way
    Nov 2012
    I have been doing a bit of work on one of these engines. I believe it is a 2nd Gen 3SGTE out of an ST185 GT4. The large banjo bolt that supplies oil to the turbo (in the white circle) is, as you say, a stupidly large banjo bolt (I think the thread diameter was M18 - 18mm).
    You can buy plug adapters that make this a smaller and more common size:
    http://www.ebay.com.au/itm/291132125...84.m1439.l2649
    Hope this helps,
    DDD
    ummm, while it might be good for info, did you check out the date of the previous post? 7 years ago...
  1. 2TG head/ 18R block
    By quikestsilva in forum Tech and Conversions
    Last Post: 08-06-2007, 01:36 PM
  2. 2TG head onto 3TC block...need help
    Last Post: 15-05-2007, 08:07 PM
  3. 4AGE 16V block vs 20V block.
    By WHITCHY in forum Tech and Conversions
    Last Post: 21-02-2007, 09:05 PM
  4. 3S GTE Block and Head swaps
    By 2005Damo in forum Tech and Conversions
    Last Post: 08-12-2006, 11:10 PM
