Results 1 to 15 of 29
Thread: 3sge beams sump mods?
    5 unit 6 tanner st
    Default 3sge beams sump mods?
    i have an altezza 3sge in my ae85 but my problem is the sump sits way to low (40mm from ground) how far can u modify them without losing reliability? was thinking bout cutting bout half off the height but make it wider with extra baffels. any help would be great!
    is firing on all eight. Carport Converter AndyTTR's Avatar
    Default Re: 3sge beams sump mods?
    On the Gen 3 and Gen 4 BEAMS 3S engines you can use a 2S RWD sump from a corona + the oil cooler fitting from a 5SFE (to fit a filter in the normal on-block position) to fix clearance problems... not sure if the same solution works for the Gen 5 BEAMS.
    Forum Sponsor Conversion King
    Quote Originally Posted by AndyTTR
    the front hosing for the oil pump+pickup and other bits need changing also so its not a 30min fix (this is for gen3 onwards) the parts need to be changed to gen2 items and then you will have a fun time sorting out the CAS that is on the timing belt pulley (36-2 pickup).
    i would probly mod the orig sump but i havn't seen one yet so couldnt tell you exactly what needs to be done.
    linden
    The 2s sump should work as mentioned above providing you baffle it
    5 unit 6 tanner st
    no way 2s will work on the gen 5, u can hardly call them a 3s bout the only similar thing between them and the other 3s would be the bore and stroke, have sorted the clearence issues now any way, raised the engine 10mm and put 15 inch rims instead of 14s, now have some 14 inch lonchamps 4 sale if anyones keen
    Adeladie
    Does anyone know what has to be done when fitting the RWD beams sump to a GEN 2?
    As in oil pump? Oil pressure relief? Oil filter?
    I want to run the filter where they have it on the beams sump and run an adaptor on the block for my oil pressure and temp gauges. Also run an adaptor on the sump to go to a oil cooler.
    Would that work?
    N/A 3SGE KE70 on its way
    you will need the whole setup from a beams (worth it?)
    by that i mean alloy sump, steel pan, oil pump, timing gear, front housing and a lot of time on your hands.
    why not use the gen2 bits and run a remote oil cooler, it would be shiteloads cheaper.
    linden
    Adeladie
    I have all the alloy and pressed sump bits including the pick up.
    Wasn't aware that the whole front would be needed. I bought it off a reconised member on these forums and double checked it with him.
    Im going RWD thats why. Would i be able to use an oil pump from a ST205? I pulled one down at work and had the same design with oil filter, pressure relief etc.
    Sorry for the hi jack and the nood question. New to 3s's
    can use the pump but i was more talking about the front housing as its way different for the sumps with the filter in the alloy section.
    even if your rwding it you can still use the orig gen2 sump bits just mod them to suit.
    linden
    Adeladie
    Dont have Gen 2 sump so it was either this or buy a gen2 one.
    What do you mean by front housing?
    everything in front of the block.
    Adeladie
    I understand about the front housing now but I still dont understand why ST205 parts can't be used? I would of bought new everything from toyota anyway as my work as an account with toyota so i get trade prices.
    Sorry if it sounds like im being rude just trying to get my head around it
    EDIT: Sorry buddy been having metal blanks all day. The front housing has all the pressure relief and shit in it. So in thoery that could be swap for a ST205 (not up with all the GENs) and should work
    gen3 may work but not 100% sure as they may have changed the galleries in gen5.
    linden
    if i get time i may look it up in the epc
    Adeladie
    Cheers Buddy. Had me streesin' for abit there.
    Cant see why they would of changed the galleries though.
    I have pics of the beams sump if it helps. Not full detail so you can see the galleries but just where they join to the front housing
    http://www.toymods.net/forums/showpo...4&postcount=20
    http://www.thor-racing.co.uk/3SGE_Bl...ams_Engine.asp
    which sump did you get? fwd or rwd? note that the st205 being EW might not work the best for you.
    st205 and beams are essentially the same. the beams fwd versions have an area cut out for the CAS. if you need a pic let me know.
  1. Are 3sge beams motors interference motors?
    Last Post: 21-04-2007, 05:31 PM
  2. Cressida MX73 Conversions Guide Book
    By twentyEight in forum Engine & Driveline Conversions
    Last Post: 24-02-2007, 11:07 AM
  3. Simple 3sge Mods
    By Lonewolf in forum Tech and Conversions
    Last Post: 18-02-2006, 02:47 PM
  4. Sump position model guide (SPG#)
    Last Post: 31-01-2006, 02:15 PM
