I'm guessing you'll probably spend a few hours plus $20 in fittings to make your own... or you could do what i did and just buy a Turbotech one off ebay for $30 and pay for it by going to work for a few hours.![]()
After seeing the tubotech items on Ebay and some people trying to flogg off their own DIY items on other forums I thought I would see if I can find some instructions on how to build them. It's really quite easy. I did have a bit of a search and didn't see any other posts mentining it so here goes. I will eventually build one when I get some spare time but if anyone has a crack before me the only thing that isn't really explained is the spring rate used so maybe post up what springs you have had success with.
http://www.geocities.com/chmwatson/FAQs/mbc.html
Hello.
Simon.
1991 Toyota Cressida (JZX83).
Autospeed have a few DIY articles on their website on how to make your own BCs. I know i drew up some designs for a BC based on those articles on Autospeed, never made it though.
MA61 Part Numbers, Upgrades and General Infomation <--- Clicky Clicky
If you want to make your own, get a norgren valve...you will need two.
One pressure relief valve
One pressure regulator valve
I'll try and find what I did with the writeup.
Hits boost like an animal, and regulates it very effectively.
244rwkw / 328hp @ 18psi
you're probably right. In my case I have most if not all of the bits laying around already so it will cost bugger all to make. and it's funOriginally Posted by Slim
Excellent link. + rep 4 uOriginally Posted by Ribfeast
Hello.
Norgren valves are available from "HIS Hose" and prob other places.
www.hishose.com.au
I also tried the Turbotech unit but found the Norgren valve setup to be more effective.
Better links on the boost controller are here, with a better valve design you may want to purchase instead:
http://autospeed.drive.com.au/cms/A_0685/article.html
And the original article (in case you don't like PDF, or want to click on pics)
http://autospeed.drive.com.au/cms/article.html?&A=0670
