Page 7 of 16 FirstFirst ... 56789 ... LastLast
Results 91 to 105 of 227
Thread: $250 vented brake upgrade for KE30/35/55 also celica/corona
  1. #91
    Default Re: $250 vented brake upgrade for KE30/35/55 also celica/corona
    Factory parts from other Toyotas would be aftermarket to the Toyota you have IE not OEM for that vehicle.
    Bending struts... I am concerned, as I don't believe that is compliant with ADRs.
  2. #92
    adr's would not have anything to do with it
    adr's relate to original design rules for manufacturers
    ncop or in vic for example the VSI's is a different thing entirely
    i pulled three hundred rocks from the land to build my house
    i walked quiet through the forest like a tiny quiet forest mouse
    the oceans will rise
    please stand by the shore
  3. #93
    NCOP etc are a guide to ensure the ADRs are complied with. Sorry, but anything you do in contravention of the ADRs is illegal... and won't pass an engineering inspection (unless well hidden, and may present itself during a post-crash inspection, rendering your insurance invalid)
    Keep it safe people, your life isn't worth a few bucks saving.
  4. #94
    the modification guidelines say that anything that is a factory part and is swapped over in the brakes or the suspension department is considered to be completely legal and not needing compliance or inspection. It may be a victoria only thing I though. I can find the relevant clauses?
  5. #95
    i'm fairly sure that would only relate to that particular model of car. Ie you could use the ra23 gt suspension on an lt ra23 as it is the same model. If you were to turn around and use rt130 struts - whilst they fit fairly easily - if found after an accident that they are not the original equipment and were not engineered for that car then your insurance can be invalid!!!! Hence why when mine is all in and ready it will be getting engineered and blue plated.
    It would be interesting to see the clauses to interpret.
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
  6. #96
    Ben is on the money. Swapping out for factory parts from a vehicle model other than the one being swapped into is considered in the same boat as aftermarket, and thus not a factory replacement part.
  7. #97
    I would love to eat a... Domestic Engineer Sagluren's Avatar
    south australia
    good thing i cant get insurance for a while, i was thinking some adjustable strut top would do the trick, as it is only out buy a degree and a bit, it would defiantly but one of the new struts as my old original items were still within specs.
    anyhow, ive now done 500km with these including a near accident and they are still going strong.
    cheers sam.
  8. #98
    Nov 2007
    Copied from the department of transport website:
    4.2 Any additions and/or modifications to the original vehicle must be supported by evidence of ADR compliance
    Engineer's certificate shows compliance of modified parts. Bent struts are ok provided an engineer passes them.
    Even mods like aftermarket light gas discharge lamps for example, require compliance with, you guessed it, ADR's. They require the vehicle be fitted with self leveling rear suspension and headlight washing system to pass.
  9. #99
    Quote Originally Posted by af300e
    That's how I know it to be also...
    ([][][]II--LT--II[][][])
  10. #100
    Mar 2008
    Anything wrong with just using the entire mx62 cressida strut and brake caliper?
    come off a much larger car.
    you can also get slotted rotors for these i believe!
    according to the DBA catalogue.
  11. #101
    I have a feeling these have the traditional early 80's positive camber inducing angle. Correct me if I am wrong.
    Other things to consider, the stud pattern to bolt to the steering knuckle, strut length, insert stroke, spring seat... etc etc etc. If you can prove all of these to be ok (ie measure and fit), then I am sure there will be more than enough people thanking you for providing another source of parts.
  12. #102
    with the mx62
    - steering arm to strut bolt diameter?
    - if above NO, using mx62 steering arm, ball joint to steering knuckle taper?
    i reckon those two will fuck you up
    what length is an mx62 strut body and how does that compare to your std one?
  13. #103
    Low rep 1st year Apprentice
    Feb 2008
    victoria
    hi call me dumb but what model is xt130? celica corona? i need bigger brakes for my 4agte ke35. i just need a few Q's answered if its not to much trouble. what wheel bearings did you use? ke or xt130? i tried to do a brake upgrade a while ago with ra23 struts and hilux 4 pots but i could not get around bearing size. my car does not stop real good with the hair dryer on it as expected. and need to get onto it asap. do the ra60 disc's bolt straight onto xt130 hubs? do the xt130 hubs have the same stud pattern as ke series? would it have been easier to get xt130 springs reset and not cut off and reweld spring saddles? i dont have any trouble fabricating parts but im short on cash so i dont want to be buying lots of parts from the wreckers. this brake conversion looks like it will stop my car on a penny
  14. #104
    south australia
    xt130 is a coronna, bacause you are using xt130 struts and hubs you can use the bearing you get with them, if your lucky you can clean and repack. the ra60 disc bolt straight up to the hubs no problems, as far as i know they have the same stud pattern, it is 110x4 i think. i dont think the ke bearing top will mate with the xt130 spring, so it would be a good idea to cut and shut spring saddles.
  15. #105
    Quote Originally Posted by Sagluren
    XT130 is 4x114.3
    4x110 is KE10 and KE20 Corolla
    By The Witzl in forum FAQ
  2. Aw11 st205 GT4 Front Brake Upgrade
    By safeforever in forum Engine & Driveline Conversions
    Last Post: 21-06-2007, 11:25 PM
  3. AE86 Brake Upgrade - Here is what I did
    By Sprinter in forum Tech and Conversions
    Last Post: 01-02-2007, 11:26 PM
  4. AE86 Brake Upgrade Options
    Last Post: 07-04-2006, 03:29 PM
