RA60 rack and cross-member if you can get it engineered will suit better than ke70 setup as the dimensions of everything (including the distance between the strut tops on ra60 and ra28/3/40) will all be the same (original KE70 strut tops are slightly further apart from memory compared to ra23/8/40). Again TA022 went through this, but to get it engineered he had to weld the original crossmember points where it bolts to the chassis from the 28 crossmember onto the ra60 one, not too much of a pain but enough for him to change to a KE70 setup instead.Originally Posted by twentyEight
an ra60 setup will give wider track than a KE70 due to the further out mounting points of the control arm mounts. (the difference should be able to be boought back to within legal limits using higher offset tyres)
measurments in this link when i was down at the wreckers a while ago:
http://www.toymods.net/forums/showpo...6&postcount=32
It also mentions in the full thread that when TurboRA28 did his ke70 rack xmember upgrade it increased the track by 15mm per side, so ra60 will be a little bit more again, not much though.
