Results 1 to 11 of 11
Thread: 18R-G Fan belt
    Default 18R-G Fan belt
    Just wondering where I'd be able to get my hands on a new timing belt for an 18-RG. If so, does anyone know the part no?
    Ren.
    Default Re: 18R-G Timing belt
    Chain??????????
    Or are you talking about the water/alternator belt?
    My KE25 thread
    Default Re: 18R-G fan belt
    Yeah sorry I am talking about alternator belt
    Junior Member Backyard Mechanic Hash_ra23's Avatar
    Default Re: 18R-G Fan belt
    pretty sure its the same as an 18r one, which you can get from repco and the like.
    the alternators in the same location and the blocks are pretty much same...someone can confirm
    Thanks, yeah I called up and they're $12 from Repco. Are they easy to fit?
    shouldnt take long at all! havnt done one before personally, but just loosen the alternator and slide it inwards to relieve tension in the belt. then u can slide the belt off and put a new one on. then just slide the alternator and bolt it back like before!
    too easy.
    just confirm with someone more knowledgable that the belts are the same
    Yeah they're easy to fit. just do what Hash said ^^. take the tension off the alternator bracket and take the old belt off by feeding it through the radiator fan. Feed the new belt through the fan and tension the belt up.
    Junior Member Grease Monkey MAD79R's Avatar
    you could take the old belt with you to make sure you get the same one/same length should be the same as 18R
    fitment is easy as said in previous posts above
    (\__/)
    (")_(") ITS ALIVE
    Thanks MAD79R. Just bought one today for an 18R. I loosened the top bolt on the alternator but it won't budge. Do I need to loosen the bottom bolt as well?
    Ren.
    On some cars it does help, could be a little seized too if its been a while.
    My KE25 thread
    K Power Grease Monkey Damo82's Avatar
    You will need to loosen the bottom bolt so that the alternator can pivot in towards the engine on it.
    damo
  1. Timing belt tensioners - importance of replacement
    By Mos in forum Tech and Conversions
    Last Post: 20-06-2007, 06:46 PM
  2. 4agze timing belt 1 tooth advanced
    Last Post: 31-03-2007, 08:58 AM
  3. 1UZ timing belt... compatible accross UZ series??
    Last Post: 13-01-2007, 03:22 PM
  4. 2JZ Timing belt tensioner probs etc.
    By 2JZR31 in forum Tech and Conversions
    Last Post: 29-08-2006, 11:32 AM
  5. Timing belt part number & Toyota can not find it. Help please.
    By Nick T in forum Tech and Conversions
    Last Post: 17-08-2006, 08:51 PM
