Results 46 to 49 of 49
Thread: A70 rear subframe bushes
  1. #46
    Junior Member Backyard Mechanic byteme's Avatar
    W.A.
    Default Re: A70 rear subframe bushes
    ...maaaaan i was just there and i got the bushing back and he's a bazillion miles away... would it be ok if i organized this after the 23rd ? (got exams on at the moment)
    what duro do you want, the ones i have are 90 ?
    btw its urethane
    Hamgatan says:
    i pwn my momma
  2. #47
    Forum Sponsor Conversion King
    yeah thats no worries im not in a major rush. i didnt see the thread bump coz ive been sooooooooooo busy with work.
    90 would be sweet.
    i work on audis and VWs occasionally gimme a break
    linden
  3. #48
    W.A.
    hahaha im just messing.
    yeh 90 seems like a good number as then i also dont have to worry too much about making up all new shells and getting the urethane cast into that. With the 90 you'd just have to burn out the old bushings (leaving the stock outer shell in place), clean it up and grease em in.
    one thing i did notice though doing the front bushings (lower control arms) was that when i'd grease the bushings and press them in air pockets would form and push the bushing back out. i fixed this by drilling a 1mm hole in one half of the bushing, but is there any other way around it ?
    Hamgatan says:
    i pwn my momma
  4. #49
    Quote Originally Posted by byteme
    there is one way ive seen but never tried (i will on my car), is when you have the arm out of the car drill and tap a hole in a convenient spot in the arm and fit a grease nipple in there.
    unscrew it 2 turns to fit bushes therefore releiving air pressure and then once it goes back together you can easily regrease them every 6 months. longer bush life, no squeaks and easier to fit.
    as i said i havn't done it but it seems like a good idea.
    linden
    By The Witzl in forum FAQ
  2. AE92 Rear sus bush replacement woes.
    By Irish in forum Tech and Conversions
    Last Post: 03-08-2006, 02:26 PM
  3. MA61 Noltec and SuperPro Bushes: PN#'s and $$$
    Last Post: 19-01-2006, 07:00 PM
  4. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
