Results 1 to 6 of 6
Thread: AE92 Rear sus bush replacement woes.
    Default AE92 Rear sus bush replacement woes.
    Hi all. I have an AE92 and am having trouble sourcing the bushes on the rear hub that connect the (I think it is called) radius rods to the hub. There are two bushes on each of the rear hubs (on the disk brake hub anyway) and they tie the bottom of the hub to the rear crossmember and adjust toe. I am not talking about the one that ties the hub to a point forward of the hub on the chassis. Aftermarket eurethane bushes are avialable for the rod running forward but not for the ones I am after. Even toyota don't supply bushes for these rods and want you to replace the hub instead. Does anyone have any info on if they are available, where to get them or what they have done to rectify this problem. I am almost at the point of making my own bushes by whittling down some bigger eurethane bushes and pressing them in. Anyone have a cheap right (and left if they are cheap enough) disk brake hub that they want to get rid of in Perth? Any help would be much apreciated. The car is getting a bit dodgy to drive around LH corners now
    sa
    Default Re: AE92 Rear sus bush replacement woes.
    You're referring to the rear lower control arm bushes - right?
    I dont know if they exist. They're certainly not in any kits I know of.
    In my pic, the bushes that come with the whiteline kit are pink squares, the ones that dont are blue.
    Most places carry the bushes you want! i Know whiteline does as there on my car
    Yeah Myne, the bushes I am after are the blue ones.
    ___________________
    Glenn
    9000rpm........No problems!
    Whiteline and Nolathane don't have a listing for the bushes from what I have seen.
    ___________________
    Glenn
    Junior Member Domestic Engineer psychofox's Avatar
    I put Super Pro ones in when I had my SX Seca back in 2001. You can definitelly get them. www.superpro.com.au. I'd say Noltec would also do them www.noltec.com.au
    Wollongong Sporting Car Club - Secretary
    Current Cars:
    2004 TW Magna VR-X AWD w/6G74 - Tow Car
    1989 AW11 MR2 w/4A-GE 20V - Track Car
    By The Witzl in forum FAQ
  2. Castor Rod Bush Replacement on MX83
    Last Post: 23-11-2016, 03:41 AM
  3. MA61 Part Numbers & General Infomation
    Last Post: 27-03-2013, 12:31 AM
  4. Toyota Part Numbers - Toyota PN# for common stuff
    Last Post: 23-05-2011, 09:54 AM
