Results 1 to 15 of 22
Thread: blacktop 20V vvt rpm
    got 71? Grease Monkey cooter's Avatar
    wa
    Default blacktop 20V vvt rpm
    hey guys
    i didnt want to hijack the thread about 7age with blacktop and vvt so i thouht i start another one.
    ive just finished wiring a microtech lt10s on my blacktop 20v and am wondering at what rpm i should be getting the vvt to turn on??
    craig
    Te71 Corolla Levin, Blacktop 20v
    Te71 Corolla Levin ex Rally Car 2tg.
    Te71 Corolla Hardtop 2dr Sedan, 2tg/3t waiting
    Ke70 Corolla 4dr Sedan
    Ae86 Corolla sprinter 4ac
    Corolla Feind
    Junior Member Carport Converter Mooro's Avatar
    Tasmania
    Default Re: blacktop 20V vvt rpm
    Can't answer your question but I think with the silvertop it is activated at around 4400 rpm, whereas with the blacktop there are more factors other than rpm that activate it. From what I have read it chooses the optimal point to activate it anywhere between 1800rpm and 6800rpm based on a number of factors.
    wa
    crap. cause i think the microtech can only switch on and off.
    Corolla Feind
    New Zealand
    VVT is not RPM switched.
    for an on off application, switch on at 2000 rpm and off at 6200
    dyno testing of the off point is prob a good idea
    VVT ona stock 20v is pretty much on all the time
    once the engine is half warm, anything over 1/4 throttle switchs it on
    please, no more PMs!
    wa
    why would it be like this??
    i cant see why it would switch back to the low revs timing setting at 6000. wouldnt you want that timing setting to continue to redline?
    Corolla Feind
    New Zealand
    nope, it turns off there,
    my skillz arent sweet enough to explain the theory behind it though!
    wa
    hmm ok. i still dont think im gonna be able to get the micro to do this anyways. is there any harm in letting it stay till redline?
    craig
    Corolla Feind
    Forum Sponsor Conversion King
    Dec 2006
    dude this is the easiest answer
    tune the car with it off save map to laptop
    tune with it on
    then lay the graphs over each other one will give better bottom end, the other better top end
    set the switch point where the lines cross over and your done
    if your talking about 3d mapping it then it become hard but the above is the only way to do it properly on a microwreck.
    hope that helps
    wa
    great thanks for that roadrunner and everyone else. so ill get the tuner to set it when i get the car tuned. its still runing on base microtech tune.
    its set at 3000 atm
    craig
    Corolla Feind
    Tasmania
    tune with it on
    hope that helps
    I like this theory and I think this is basically what a silvertop does...the only thing is that I think the optimum changeover point may change depending on other factors. For instance, as a guess, the dyno will essentially be run at WOT, but the optimum changeover point maybe different at half throttle etc...I think this is where the blacktop has an improved verison of vvt.
    no backyard Domestic Engineer japlish's Avatar
    i had mine set at 4200rpm
    Dec 2006
    as stated 3d mapping is hard as you set rpm vs load and then set p/w to suit but if its switch only, the only way you should to it is wot as thats when you want it to work best.
    New Zealand
    im pretty sure the black top doesnt have a "better" vvt system.... it just switchs by a different amount.
    the change over point is pretty low, and didnt really seem to alter with half throttle or full....
    as soon as the engine is over 1/2 warm anything over 1/4 throttle switchs it.
    i had a light hooked up to the vvt solenoid, and you can sit on idle and stab the throttle and th light came on instantly. which would mean its TPS switched
    Quote Originally Posted by Mr Revhead
    Ditto for my Silvertop with std ECU
    Julian
    perth
    you can also tell the microtech to switch at a certain vacuum and rev.
    e.g 4000rpm at 3" vac
  1. AE101 Silvertop + blacktop 5speed?
    By Pure-SX in forum Tech and Conversions
    Last Post: 01-03-2007, 01:51 PM
  2. Discussion: Blacktop 20v: The road beyond 200hp
    By 86er in forum Tech and Conversions
    Last Post: 18-01-2007, 10:31 PM
  3. 16v 200mm vs 20v Blacktop Lightened 212mm FLYWHEEL
    By Matt-AE86 in forum Tech and Conversions
    Last Post: 26-11-2006, 04:18 PM
  4. Blacktop 3sge into Sw20
    By Lonewolf in forum Engine & Driveline Conversions
    Last Post: 06-06-2006, 11:23 AM
