Results 1 to 5 of 5
Thread: costs involved w50 r&r
    Junior Member Grease Monkey normo's Avatar
    Default costs involved w50 r&r
    ok
    so the w50 behinf the 18rg needs bearings.
    What is the best way out,- will a w58 slot straight in?
    What is the cost to re-race the gearbox?
    Does anyone have a cost on remove and replace a g/box in a ra28
    thanks guys
    Default Re: costs involved w50 r&r
    give me $50 and i'll have your box out in 1 hr and vice versa
    Act
    Straight up, I can tell you that the W58,7,5 all have different bolt patterens than what the W50 does, so you are looking at a bell housing change as well.
    I am also not sure on the out put splines they may be different, some one else maybe able to confirm.
    ok I asked this question about putting a w58 behind the 18r/g a little while back and got these replies. You will need a 21rc bellhousing. If you get a w58 out of RA65 or RT142 corona, you wont have to do any mods to the shifter hole. Tail shaft will bolt up, you will have to do a small simple mod with the gearbox x member. Getting your bearings, seals and syncro's replaced will cost you around the $500 mark.
    i think witzl has a 58 behind his 18rg give him a pm
  1. P51 rebuild Step by Step.
    Last Post: 03-11-2017, 10:50 AM
  2. Old Celica Transmissions Diagrams (T40, T50, W40, W50 & P51)
    Last Post: 09-01-2017, 05:45 PM
  3. 2JZGE costs involved?
    By orestes in forum Tech and Conversions
    Last Post: 01-03-2006, 11:49 AM
  4. L40 gearbox swapped for W50?
    By WDE_BDY in forum Tech and Conversions
    Last Post: 21-02-2006, 11:47 AM
  5. W50 into RT81
    By gianttomato in forum Tech and Conversions
    Last Post: 17-12-2005, 01:29 PM
