Results 16 to 24 of 24
Thread: Cracked head-What to do?
    Default Re: Cracked head-What to do?
    Quote Originally Posted by 30psi 4agte
    chemi weld is a bottle of liqiud that you can buy. You just pour the stuff into the radiator and let it do its job. If its a bad lak / crack you may need two bottles. If ts really bad ...... Get on your knees and pay !
    fixed for you
    Quote Originally Posted by kugzs
    ideally id like it to last till december. bubbling was in the radiator overflow bottle.
    Might flush it and give the chemiweld a go but if it is still no good then, the VL might be good Blake. (Would also give me a shell to fit a real motor too!)
    Get me a price and ill speak to you soon
    hey mate. he said he'd do it for $900... supply n fit it for you... but you would have to leave the car for a week, a its would be an aftre hrs job,
    If you actually want to fix the problem, try to find a cheapie replacement head, or have your cracked head welded up (ive had this done before with good results).
    agreed. it might not be a 6cyl head, but my 3S-GTE ran perfectly after the slight crack in the head was welded up. if it were a more common and readily-accessible head, I'd say just grab another one and fit it up, be done with it, but gen3 3S-GTE heads are a little harder to come by in good condition.
    TRIKKE | Video
    BTW vl's have a bleed valve on ths inlet manifold to get the air out of the system.
    Your probaby better off getting s vpmplete vl motor
    - LeeRoy
    I agree with Leeroy, those engines should be real cheap by now. Try and get one out of a skyline if you can so you dont get one thats already cracked.
    serial biochemist Automotive Encyclopaedia
    chem-weld. Or buy another RB30, they can't be that expensive anymore, can they?
    your rep rating is not a reflection of your worth to the community
    Quote Originally Posted by H1TMAN
    wtf? I want to do track racing, and f#@k you...
    that's very flattering but no thanks.
    Balloon Slayer Backyard Mechanic jimmmayyy's Avatar
    Apr 2007
    n/a RB30's can be picked up for around 200-ish second hand, and a rebuilt long motor can be bought for around 700. so it's not a massively expensive thing to fix. even just a second hand head can be picked up for 100-200. try calaisturbo.com.au for cheap parts if wreckers aren't being friendly. if you find a particularly bogan wrecker, you can ask for a skyline head and they won't charge you as much, lol. seriously!
    that said, like someone said earlier in the thread, VL's are quite common for this, (i've owned 2 VL's, lol) from the radiator being mounted below the highest point in the head and not being bled properly by BOGANS.. so as soon as the coolant level drops a little either by overflow or whatever, they overheat easily. the heads literally split open down the middle under the cam. i wouldn't bother welding it, since you're are gonna have never ending problems snapping cams coz the head WILL warp. they are never the same again after welding.
    if you do fix it, there's a bleed bolt in the top of the manifold at the front. above the pcv. crack it and let it bleed with the car pointing uphill, lol. it'll never give you problems again.
    any other probs you have lemme know, i know these turds fairly inside out. the motor is the only saving grace for this car funnily enough.
    -jimmy
    currently toyotaless Grease Monkey rn-85's Avatar
    Canturbury
    a mate of mine used quick steel on a camry head and it never faulted again and he's sold the car now. how much does the car mean to you? the soulitons are endless.
    Knowledge is knowing a tomato is a fruit.
    Wisdom is knowing a tomato has no place in a fruit salad.
    burn it and buy a toyota.
  1. Replacing head bolts with studs.
    By PHOBIA in forum Tech and Conversions
    Last Post: 17-09-2011, 11:36 AM
  2. TG engine info!
    By MitchE in forum Tech and Conversions
    Last Post: 30-07-2010, 06:27 PM
  3. 1JZ performance head build. Advice/help?
    By ReQuieM in forum Tech and Conversions
    Last Post: 09-07-2007, 08:08 PM
  4. 2tgue & 3tgtue info
    By chippa07 in forum Tech and Conversions
    Last Post: 06-01-2007, 07:29 PM
  5. 3s-GE Head gasket
    By SilverSt162 in forum Tech and Conversions
    Last Post: 03-08-2006, 08:44 PM
