Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 46 to 60 of 104
Thread: 1J Gurus - spark plug advice
  1. #46
    Forum Sponsor Automotive Encyclopaedia dori dori's Avatar
    Default Re: 1J Gurus - spark plug advice
    I'd say it'd have to be. Cant see single coils having built in sequential abilty for the 2 outputs
    Yep, VVTI turbos (not sure on n/a) 1JZ and 2JZ come with 3 coils so waste spark
    I can get the coils for about $730 for the set. I have a mate at CHT and thats well under trade price.
    I dont like the idea of external. WHy cheap out when you have gone to the trouble of a whole conversion or mods.
    Plus, then you add in more wear and tear parts, like ignition leads. Which are prone to playing up in a shorter space than coilpacks which prove that they can last for up to16 years.
    I dunno, its the way i see it. Why change a good system. Coil on plug, doesnt get any better.
    11.72 @ 116.7mph = Quickest Stock Turbo Jzz30 series Soarer And 1st into the 11's WOOOT!!!
    Still going good
  3. #48
    How do you get a set of the factory coils to last 16 years? (apart from leaving the car in the garage )
  4. #49
    I would agree with DT if you were stock ecu but as you have a microtech I would slap some bosch ones in there. One big positive with this way is you can take plugs out in a few seconds instead of minutes which is a good thing at the track. That would be a big positive for me.
    Only issue is mounting brackets and running leads. No it doesn't look as neat as COP but if it makes more power and is cheaper I would be doing it. (infact I would have already if PVC glue stuff wasn't free for me )
    QUICKEST 1JZ'S IN OZ
  5. #50
    Chris i'm liking the idea of being able to remove the plugs easily, its been frustrating the last few weeks trialling sparkplugs and trying to diagnose the ignition miss, would be so much easier without coil on plug. I can still make a neat looking setup with the coils on the firewall & leads entering under the original cover at the back.
  6. #51
    Supra Addict Grease Monkey Enigma-Penguin's Avatar
    Aug 2006
    Quote Originally Posted by 1JZ-Rolla
    Here are a couple of pics. I didn't look very carefully for cracks the first time because the coils looked almost new compared to the other posted images of cracked coils, where the whole coil looked pretty crappy & you could see other signs of excessive heat.
    Glue and shrink wrap did these just fine, hopefully they'll last at least a short while:
    Seemed to look less tacky to me than taping
  7. #52
    lol man that looks awesome! Top shit!
    Malicious
  8. #53
    good thinking on the shrink tubing!
  9. #54
    ns why didnt i think of that!
    JZA70|R / 12.45 @ 111 mph.
  10. #55
    BOSCH coils cost me $300
    leads i cant remember
    but i woudl say it was a ship load cheaper than $730
    8.3 et PB 169 MPH PB
  11. #56
    I just bought some of this "Liquid Electrical Tape" stuff and put it on the coilpacks. It seems a lot more robust than the PVC glue, which tends to flake off or peel away from the coilpack over time slightly (probably because of the heat). It is around $20 from Jaycar for a can of it.
    Apparently glass insulation tape over the coilpacks is the way to go (after doing this), but I haven't been able to track any of that down yet.
    Excellent idea above with the heatshrink, I'll probably give that a go too, assuming the rubber boots still fit over the heatshrink.
    No more misfires for me
    244rwkw / 328hp @ 18psi
  12. #57
    Here's my solution:
    Please ignore the mis-matched leads... I need to order a custom set. Any recommendations for a good lead suitable to use with aftermarket ECU (ie: good suppression for no interference)?? I was thinking TopGun pro racing series 10mm leads.
    The good news is no more ignition miss and no more brittle plugs & wires to the coils under the cover.
  13. #58
    That looks nice! I found out a couple of my coils are starting to crack today. Might have to harras my mate that works at bosch for cheap coils!
    Malicious
  14. #59
    HAHA Did I sell you that catch can??? I swear I sold that on here about 2 years ago now! Good to see its getting used in a good machine! It was a good catch can.
    Malicious
  15. #60
    Western Aus
    i dont like the look of the coils being extrenally mounted, it takes away from the stock look.
    and thats saying something, as that single turbo conversion looks factory!!!
    Elmo.
  1. Wasted Sparks VS Sequential Spark
    Last Post: 07-01-2018, 11:19 PM
  2. Oil in spark plug chamber 3sfe
    By dundee230966 in forum Tech and Conversions
    Last Post: 09-04-2007, 11:46 PM
  3. 4AGE Spark Plug Cover
    By AE92 Rolla 4A-GTE in forum Tech and Conversions
    Last Post: 29-10-2006, 05:13 PM
  4. Spark Plug Question
    Last Post: 22-05-2006, 07:09 PM
